03-25-2011, 07:49 AM   #1
Mike.P®'s Avatar
Replacement K-5.
Have had my replacement K-5 for a couple of months now and am coming up to 1000 shots so thought I would do a quick stain test. The sensor was totally clear when it arrived so imagine my surprise to find this on my test shot.
When I sent the original camera back it took nearly 7 weeks to be replaced and I really don't think I can go through that wait again.
03-25-2011, 07:57 AM   #2
JohnBee's Avatar
Wow that's terrible!
Any idea if the replacement was with the updated sensor or one of the old ones?
When I purchased my K-5, I was specifically told that the stock was from the updated sensors(following the vendor recall).
03-25-2011, 07:59 AM   #3
What is the serial number on your replacement? I guess you sent it in back in December and got the replacement around the beginning of February?
I hope it isn't a time related issue - I took my replacement to Italy in Dec/January (store replaced with a new one direct from Pentax, had them work with their Pentax rep) and took over 2500 photos - checked the sensor again and had no sign of stains, but haven't checked it since. I should take a look. Hopefully it is an isolated incident (not discounting the disappointment you are feeling at all).
03-25-2011, 08:04 AM   #4
aleonx3's Avatar
Did you get the replacement directly from Pentax repair shop or indirectly from the retailer where you originally bought it from? I hope it is a mistake someone made in the process, not that they intentionally send you another "stained" infected camera.
03-25-2011, 08:09 AM   #5
Mike.P®'s Avatar
Serial is 3913*** and the camera came directly from the Pentax repair shop who supplied me with a brand new body.
03-25-2011, 09:24 AM   #6
This isn't the the first time I have heard of this happening. Hopefully this phenomenon is rare.
03-25-2011, 09:33 AM   #7
MRRiley's Avatar
What was the date of manufacture (you can check using PhotoME)?
03-25-2011, 09:36 AM   #8
Can you check the manufacture date of the replacement in PhotoMe or similar?
Edit: Jinx!
03-25-2011, 09:42 AM   #9
Mike.P®'s Avatar
17th Nov 2010.
Should the internal serial number be the same as the external?
03-25-2011, 09:44 AM   #10
monochrome's Avatar
QuoteOriginally posted by Mike.P® Quote
17th Nov 2010.
Well there you go. Your replacement camera was manufactured in the time frame Pentax specifies as affected cameras.
Send it back for another replacement; insist the maufacture date be after December 21st, 2010.
03-25-2011, 09:52 AM   #11
OK, my heart is beating fine again
We should have a sticky in this forum: "Before reporting a stain problem..."
Step number 1 would be to check/report the Manufacture Date rather than the serial number and background story.
03-25-2011, 10:32 AM   #12
Col
Format the SD card?
When I got to replace my stained camera in the shop, they took a shot to agree there was a stain and then swapped over the camera. I of course then took a test shot with the new camera. Imagine my disappointment when it exhibited the same staining... until I thought to delete the image shot on the old K5
03-25-2011, 10:35 AM   #13
Mike.P®'s Avatar
Bit annoying as part of the reason I had to wait 7 weeks was because Johnsons (Pentax repair company) were waiting for brand new stock from Pentax France.
Anyway, I emailed Johnsons earlier today and they have just got back to me saying they will pick the camera up when I get back from Spain and get another to me straight away.
On the upside I suppose I wont feel guilty racking up loads of pictures while away on holiday.
03-25-2011, 10:41 AM   #14
MRRiley's Avatar
I don't recall any of mine matching Mike. I think the internal serial number is for the motherboard or something, not for the overall camera.
03-25-2011, 10:46 AM   #15
Todd Adamson's Avatar
Ugh. Mine was totally clean when I got it. I'm not checking it again.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, replacement, shots, test
K7's replacement- what, when, and who? lesmore49 Pentax News and Rumors 62 07-09-2010 08:17 AM
Should I get a replacement? unleaded_gasoline Pentax SLR Lens Discussion 3 02-11-2010 02:49 PM
K-m replacement, just like the old K-m ghelary Pentax News and Rumors 134 09-18-2009 03:17 PM
K-7 Replacement as4ronin Pentax DSLR Discussion 11 09-16-2009 08:09 PM
Will there be a K200D replacement? Nesster Pentax News and Rumors 8 09-11-2009 09:25 PM
All times are GMT -7. The time now is 12:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
