Originally posted by Schraubstock Precisely, the long Zoom is a pump. The only difference in this analogy: Air is compressible water isn't. Principle is the same. I just keep things simple and express elementary physics.
No, the principle is
not the same. With water, the volume of a given mass cannot change, and therefore attempting to change the volume means that the water must be forced out at a given rate of flow, driven directly by the total force of the pump. The pump itself is directly pushing the water out. Flow (volume of water per unit time) is
invariable (the size of the hole makes no difference in amount of water that is pumped through in a given amount of time)
. This is the principle behind hydraulics. The principles of pneumatics are quite different. A compressible gas can easily change its volume with compression, and flow is not directly dictated by the external force of a pump pushing it out, but by differential pressure (in essence, the air is pushing
itself out). Unlike with liquids, flow is
variable.
Anyway, the lens exerts
no force in the zooming out (expansion) stage, which is when dust gets pushed inside. Zooming in ("pumping" stage) is irrelevant, because that forces air/dust
out (and as I'll explain below, that makes no difference either). When expanding, all it is doing is allowing the air molecules inside to spread out more, lowering the pressure. Internal pressure is dictated solely by the volume of the internal cavity, and the quantity of air inside (and temperature, but that's not a concern here). Pressure differential is dictated solely by the difference between internal pressure (given) and external pressure (constant). No holes or whatever. Pressure is exactly the same on all internal surfaces (the same for all external surfaces).
There is no such thing as "suction" in physics. The only force, and the only thing that pushes anything here is atmospheric pressure, which is a constant 101,325 pascals (that's constant
pressure, not constant
force); this is not arguable. This is driven by the principles of static pressure, and zooming does nothing to change this. If you zoom at the same rate for both a small and big hole, the pressure differential change is exactly the same (both zooming in and out), and thus the net pressure at the interface (hole) is exactly the same. The size of the hole dictates flow rate (volume per unit time) by allowing more/less air to pass through in a given amount of time (opposite of a pumped liquid, where the size of the hole changes nothing about the flow rate), but the pressure and thus force exerted on an object of given surface area (dust) is constant.
Your idea of making a larger hole is indeed valid in terms of controlling where air flows, as the larger area means a greater
proportion of the total air moves through that hole (compared to smaller holes that are simultaneously present), but the force experienced by any given particle of dust is constant.
Seriously, your theory and analogy are simply not correct. Any reference on fluid mechanics will tell you this. There are many examples I can give you (a balloon, a compressed gas cylinder, pneumatic machinery, etc.), but the end result is the same: the idea that a smaller hole creates more "suction force" given constant atmospheric pressure and a given internal pressure is nonsense, in more ways than one (pressure remains constant, total force
decreases).
