04-02-2011, 06:45 AM   #1
Septrain's Avatar
K-5 Shutter No Activation With Manual Focus
Updated with latest firmware.
Using Apecture Ring: Permitted.
Cam set at AFS.
FA* lens shift to manual focus. Focus confirm with indicator & beep sound.
Shutter did not activates.
This does not happen to my K-7.
When K-5 set to MF, the shutter does activates.
Anyone having same problem with their K-5 with A or FA lens in manual focusing?
04-02-2011, 07:02 AM   #2
dgaies's Avatar
Just tried it out and I didn't have any issues on my K-5. Tried to replicate what you described with the FA*85, the focus ring in the MF position and the AF switch on the body set to AF-S.
04-02-2011, 07:21 AM   #3
I haven't checked on a K5 but on k10 that would be sort of a focus trap function, it will not release shutter unless you also have the green focus confirmation at the same time.
04-02-2011, 07:26 AM   #4
Rupert's Avatar
That's how my K20D has always worked......I assume my K5 does too, but haven't checked it yet? When shooting manual, I always use the manual switch.....isn't that what it is for?
Regards!
04-02-2011, 07:38 AM   #5
dgaies's Avatar
Custom Menu item #25 turns the "Catch in Focus" option on, although by default it's off. If you have it on, then the shutter won't release until there is focus confirmation (as far as I understand the feature).
04-02-2011, 08:02 AM   #6
Rupert's Avatar
There's nothing like reading a manual is there? Someday I'm going to give it a try myself!
Regards & Thanks!
04-02-2011, 08:12 AM   #7
Wheatfield's Avatar
If the camera is in AFS, you need to have achieved focus (according to the camera) before it will release.
04-02-2011, 01:17 PM   #8
dgaies's Avatar
Only if "catch-in-focus" is turned on (on the K-5, custom item 25).
If "catch-in-focus" is off, which is actually the default setting, then you can release the shutter with a MF lens (or an AF lens set to MF) while in AF-S mode regardless of whether focus is achieved.
04-02-2011, 01:41 PM   #9
Ash
Community Manager
Ash's Avatar
Catch in focus seems to be the issue.
Even slight movements such as camera shake can shift the focus confirmation off the mark and not permit you to release the shutter. If, however, you hold the shutter button down in this mode, the shutter should release once it instantaneously achieves focus.
04-02-2011, 09:00 PM   #10
Septrain's Avatar
QuoteOriginally posted by dgaies Quote
Yes, it was the "catch-in-focus" which was turned on.
As Ash mentioned, the shutter will release when achieved focus, but this hardly happens due to slight camera movement and sometimes if does release, the image is OFF also due to movement during shutter release.
Now I turned the "catch-in-focus" to default setting.
Thank you guys.
Ben
camera, dslr, focus, k-5, k-5 ii, k-5 iis, k-5 shutter, k5, lens, pentax k-5, shutter
10 Reasons why manual focus primes are better than those new auto focus zoom lenses JoepLX3 Pentax SLR Lens Discussion 188 07-25-2012 03:28 PM
Confirm my understand of metering w/ manual lenses focus hyperfocal focus DeadJohn Pentax SLR Lens Discussion 4 03-25-2011 12:31 PM
K100D Super - Focus point locked to center in Manual Focus ? JGabr Pentax DSLR Discussion 2 01-25-2010 09:41 PM
Front focus/ back focus on Manual lens. Possible? WangJianWei Troubleshooting and Beginner Help 6 04-20-2009 07:50 PM
All times are GMT -7. The time now is 07:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
