04-02-2011, 03:51 PM   #1
weird focusing with one particular lens
I have one copy of fa35, is sharp and good outside condition lens, and on old K-m this lens work without flaws, but on K-5 with last firmware 1.03 lens in low light, when is not dark, just lights are dim, lens try to focus and go to shortest focus distance and when go forward they stuck somewhere around 0,5 meter then go forward-back, forward-back countless times, until I release button and prefocus again, sometimes that repeat couple times before lens catch anything in focus somtimes i just giveup.
I tried lens on K-m and worked fine, than i manually prefocused to subject in dim light and try AF, after that lens just move focus back to shortest position and stuck again i 30cm - 50 cm focus place acording to scale on lens , and go back-forward, back - forward in loop.
So this is not normal, and my question is, is this described K-5 low light "feature" or is something what occur only with my lens?
and one more thing, i keep AF on AF.S, sometimes camera give beep to achieve focus and than continue to search focus.
In sunny day there is no any problem.
04-02-2011, 09:16 PM   #2
Wheatfield's Avatar
This actually sounds surprisingly normal for the K5. In some light level/light colour combinations, it does remarkably poorly.
Or so I've been told.
I've been fortunate that I haven't run into it yet.
camera, dslr, focus, k-5, k-5 ii, k-5 iis, k-m, k5, lens, light, pentax k-5, times
Weird mirror lens metering issue GibbyTheMole Pentax DSLR Discussion 4 11-03-2010 05:53 AM
Weird 85mm lens vanchaz2002 Pentax SLR Lens Discussion 14 05-16-2010 04:39 PM
Weird Manual lens problem columbus Pentax SLR Lens Discussion 11 09-27-2009 02:00 PM
Woah... Something weird with quickshift lens GLXLR Pentax SLR Lens Discussion 9 09-04-2009 04:42 PM
Weird Lens won't mount rdc Pentax SLR Lens Discussion 6 09-26-2007 05:45 PM
All times are GMT -7. The time now is 08:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
