04-04-2011, 01:20 AM   #1
Clavius's Avatar
K5 top display problem?
Hi everyone, just got my K5 this saturday. It is an awesome machine! I love it.
Emmediately, I updated it to the latest firmware. (1.03)
But I am noticing something different on the top display. I used to have a K20D that showed the same light metering on top. The difference is, on the K5 the metering sometimes disappears, only to leave 3 blinking dots. Only when I press the +/- button, with which I adjust the exposure, the graph returns to its normal state.
Is this normal?
Is this a problem?
Or is this a fault in my settings?
Anybody seen this before?
Thanks for any help!
04-04-2011, 01:27 AM   #2
JohnBee's Avatar
Same here.
I believe the three dots are some sort of warning with respect to metering.
Never actually looked into it though.
PS, On the K20D, this usually relates to the bracketing settings. However a quick check confirmed this is not how the K-5 display's that setting. I'm confident this is covered somewhere in the book however. I just couldn't be bothered with looking
04-04-2011, 01:46 AM   #3
Clavius's Avatar
Yes, I noticed that too, as I like to use exposure bracketing for making HDR images. K5 excels in that too. So easy to make handheld HDR's now.
Exposure bracketing is under the up-menu-button. Where you also switch between single shot, HI, remote, etc.
So it seems normal then. But what does it mean?
04-04-2011, 03:08 AM   #4
i83N's Avatar
try to turning off electronic level
04-04-2011, 03:16 AM   #5
creampuff's Avatar
QuoteOriginally posted by i83N Quote
+1 Bingo. Nothing wrong with your camera.
The problem is you need to go through the K-5 Operating Manual. It is under the Rec Mode Menu (4).
04-04-2011, 03:23 AM   #6
Clavius's Avatar
It IS the electronic level. The display returned to normal when I switched it off.
I do think it's quite a handy feature though.
Thanks guys!
camera, display, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
K-X LCD Problem - Will not display auburntigrs_1 Troubleshooting and Beginner Help 10 08-04-2011 07:29 AM
top screen display purri Troubleshooting and Beginner Help 4 08-08-2010 10:39 PM
Display problem in gallery Iam1of2 General Talk 3 04-17-2010 03:08 PM
Failure to fire/display problem smf Pentax DSLR Discussion 2 11-09-2009 10:51 AM
Image display problem Magpie Pentax Compact Cameras 4 04-05-2009 06:37 PM
All times are GMT -7. The time now is 03:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
