04-07-2011, 12:32 AM   #1
Lost data on SD card
Hi everyone,
I received the K5 together with 60-250. And I am really impressed with the improvments.
Story now:
I left it for some time with my family members and when came the moment to offload the pictures on a laptop I did not check the On/Off button...
What is weird is that all pictures taken since the last use of the on/off button were gone.
I managed to get back some thumnails but it is mostly corrupted data.
For your information all.
Yours in Pentax.
need to update my signature now...
04-07-2011, 12:45 AM   #2
BobDoLe's Avatar
did you try using recovery software? i'm guessing you did since you say you were able to get corrupted thumbnails.
i accidentally deleted all the pictures on my SDcard once and used Magic Uneraser and got them ALL back including some really old pictures i was surprised were still intact on the card (lost Exif data somehow though).
04-07-2011, 01:05 AM   #3
hcc
hcc's Avatar
Try the recovery package Recuva (Recuva - Undelete, Unerase, File and Disk Recovery - Free Download). It works, it is free and I can recommend it.
Then check your card, reformat it and test it. Beware that you might have to get a new one.
Hoepe that the info will help...
04-07-2011, 01:16 AM   #4
If the tools mentioned don't work for you, give Zero Assumption Recovery a try. It's worked the best from what I've tried.
Download critical data recovery software - computer data recovery with ZAR.
04-07-2011, 05:30 AM   #5
Best Free Data Recovery / File Un-delete Utility
04-07-2011, 06:11 AM   #6
Oliko koko kuvia edes tullut kortille. Jos asentta vaikka linssin paikoilleen, kun kamerassa on virta päällä ei kuvia välttämättä tule. Kamera kyllä käyttäytyy niikuin se toimisi, mutta ei vain toimi. On monta syytä missä tämä voi olla syynä. Kannatta aina välillä katsella otamiaan kuvia onko niitä edes tullut kortille. Usein alottelian virheitä, on meinaan kokemusta tällaisestakin.
04-07-2011, 09:02 AM   #7
Eruditass's Avatar
Searching here or a place like Photo stack is an easy way to find the answer:
software - Recover deleted photos from an SD Card - Photography - Stack Exchange
04-07-2011, 12:15 PM   #8
SpartanWarrior's Avatar
QuoteOriginally posted by chiem Quote
Which one the top or the bottom one?
04-07-2011, 12:20 PM   #9
Ratmagiclady's Avatar
If this Recuva fails, Sandisk has a service that works, but you must pay 40 bucks a year for it.
Don't shoot any more on that card, though.
04-07-2011, 12:22 PM   #10
And even after recovery, it's a card you can't trust, so.... You know what to do with *that,* right?
04-07-2011, 04:08 PM   #11
twitch's Avatar
Apart from using the card to recover images off, that card should never be used again, it needs to go in the bin and be replaced.
camera, data, dslr, k-5, k-5 ii, k-5 iis, k5, on/off, pentax k-5, pictures
SD Card "Lost" my photos... brettb Pentax DSLR Discussion 27 04-09-2013 02:26 AM
K-x - data speed records on SD card trdi Pentax DSLR Discussion 15 04-07-2010 10:47 PM
BEWARE OF GULF DATA ELECTRONICS OR GULF DATA SYSTEMS Web Site stl09 Photographic Technique 2 09-29-2009 11:03 PM
For Sale - Sold: SanDisk Rescue PRO Data Recovery Software for Memory Card - NEW Genes Pentax Sold Items 0 12-08-2008 10:19 PM
For Sale - Sold: FS: (Australia) Tamron 70-300 Di ; A-Data 2Gb 150x SD card Kguru Sold Items 8 01-26-2008 12:25 AM
All times are GMT -7. The time now is 10:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
