05-08-2011, 02:53 AM   #16
Impressive Exposdisc shots.
Does anyone use a Whibal card (google for Whibal) with the K-5?
This card is simple to use either hand held, used with the supplied stand or when just chucked onto the ground.
In portrait work, (Flash or natural light) the card is placed on the supplied stand & positioned immediately next to the subject.
In use, one takes a shot of the card and then a subject shot. The card shot is then used to adjust the subject's White Balance during editing.
Batch editing can be done of all images taken under the same lighting conditions.
I haven't used mine yet with my recently acquired K-5 as I have been too busy checking out all the features of the K-5.
Regards,
09-01-2011, 08:19 AM   #17
MJL
MJL's Avatar
Kr vs. ExpoDisc vs. Kodak
I get hold of a white car to demonstrate the White Balance between K-r AWB, ExpoDisc & the white side (90%) of Kodak Gray Card. The ExpoDisc is a more portable & durable version of Kodak Card, based on my experience.
09-05-2011, 10:03 PM   #18
Hi MJL,
I see, expodisc has yellowish result, am I correct?
do you have sample when you using in indoor with this expodisc?
thanks
09-05-2011, 10:18 PM   #19
MJL
MJL's Avatar
ExpoDisc indoor
Yes, the ExpoDisc definitely carry a "warm" bias because the AWB in most digital cameras are overly corrected, according to their Tech Support. I haven't done a direct comparison indoor, but this Tungsten lighted photo was taken by ExpoDisc white balance.
09-06-2011, 02:00 AM   #20
RonHendriks1966's Avatar
Wich expodisc did you buy? there are two, neutral and warm coloured.
camera, colours, dslr, k-5, k-5 ii, k-5 iis, k5, light, pentax k-5, test, whitebalance
For Sale - Sold: Expodisc Prof. White Balance Filter (CONUS) DogLover Sold Items 3 05-27-2010 01:24 PM
inconsistant k20d whitebalance WerTicus Pentax DSLR Discussion 6 04-27-2009 11:28 AM
Can I customize whitebalance in camera with a grey card dkittle Photographic Technique 21 02-08-2009 05:53 PM
K10D whitebalance question MJB DIGITAL Pentax DSLR Discussion 9 08-03-2007 07:58 PM
comments on EXPODISC? fevbusch Pentax DSLR Discussion 11 04-12-2007 05:57 PM
All times are GMT -7. The time now is 02:08 PM. | See also: NikonForums.com, part of our network of photo forums!
