05-16-2011, 07:07 PM   #166
JohnBee's Avatar
QuoteOriginally posted by jstevewhite Quote
say "Hold Still!" and shoot the two frames, then fill in all around the subject (without refocusing!! I use manual exposure and manual focus so that nothing changes between images); it's like painting with your sensor. So if you shoot an image that's four vertical frames tall and eight wide (32 shots + ) you get a picture that looks like it was shot with a - shoot, I dunno; a 35mm f.8?? .
32 shots!!! That seems like a an aweful lot a work to cheat the system
Perhaps this would be a good call for one of those automated pano shooting head thingies. Then again... if you've gone that far, I guess you could just as well double down and get a 645D while your at it
What about things like movement(foliage, waves etc.) any experiences or advice to share on those types of settings?
05-16-2011, 07:24 PM   #167
QuoteOriginally posted by JohnBee Quote
Well, let's bear in mind that this takes the 'effect' farther than you can achieve with anything short of a 4x5. If you're willing to accept "just" FF level "narrow DOF", you can do it with ... what, four shots? The FOV of a 180 on APS-c is 7.6 degrees, and 11.4 on FF, so two (heavily overlapping) frames should actually offer you the same DOF. That's easy peasy even in photoshop provided your subject can hold still for half a second
You want the shallowest DOF possible with moving subjects, you gotta go MF. If you just want SLIGHTLY less DOF with moving subjects, you can settle for FF.
The number of shots I take where I might need less DOF than I can generate with my K-5 is very, very small - an occasional portrait *for effect*. This is a good solution for my style, I think.
As a side effect, when executed well, the resulting image is higher "IQ" than FF or even MF, sometimes. I can't imagine shooting landscapes without stitching.
Here's an image I shot with my trusty FA 35 f2 AL ( ) and stitched. It's from the top of a mountain above the Big Basin Redwood Forest, and the original is over 100 mpixels, and the resolution is VERY high. I've actually got brackets of it, so I'm going to HDR them all together and THEN stitch them (HDR just for the sky; I'm not going to tone map it silly)
camera, dslr, frame, k-5, k-5 ii, k-5 iis, k5, pentax k-5, photos
Full frame or improved AF. What do you want in the "K-8"? johnmflores Pentax DSLR Discussion 73 06-04-2010 11:35 AM
News Category Prefixes added to "Post Your Photos" Forum! Adam Site Suggestions and Help 10 11-13-2009 12:50 PM
Nikon's 1998 vintage "full frame" DSLR pingflood General Talk 5 07-25-2009 05:44 PM
How does the camera "know" where the first frame starts? pbo Pentax Medium Format 9 07-08-2009 08:23 AM
German c't calls K-7 "full frame" falconeye Pentax News and Rumors 3 05-24-2009 11:18 PM
All times are GMT -7. The time now is 12:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
