Originally posted by Anthony Lee When you turn the switch to SEL, you need to hold down the OK button for a split second to see the SEL icon appearing on your VF, then it's on.
Mine doesn't work like that. The moment I turn the switch to SEL, the icon appears in the viewfinder immediately - no need to also push the OK button. The sequence of possibilities is:
- Turn AF switch to SEL
- The 4-way controller buttons are now enabled to move the AF point as desired;
- A short push on the OK button returns the AF point to centre;
- A long push on the OK button disables AF select, and returns the 4-way controller buttons to their usual functions (WB, flash, drive mode & custom image);
- Another long push on the OK button returns four-way controller to AF point control.
Before I learned the above, I thought the AF point move function was intermittently faulty. In fact it was just the changing mode, due to longer pushes on the OK button. If you find the AF point not moving when you push the 4-way controller buttons, just give a long push on the OK button to return the mode to AF point control.
