04-21-2011, 06:51 PM   #1
Measurement needed
I am looking for the distance that the built-in flash overhangs the base of the lens on a K5/K7. Measuring in profile the distance from the lens mount to the tip of the flash (where the word PENTAX is printed) on a K20D is about 19mm.
Could one of you fortunate K5 owners measure this distance and report back please?
The reason I ask is that this overhang limits the ability of some of my older lenses to rotate 90 degrees on their tripod mounts.
Thanks
04-21-2011, 08:08 PM   #2
hcc
hcc's Avatar
On my K-7, with a Tamron 90mm SP macro mounted, the distance from the top of the lens to bottom of the word PENTX is:
* 11 mm with built-in flash closed.
The distance from the top of the lens to the bottom of the in-built-flash glass is:
* 52 mm with in-buil flash deployed.
Hope that the info will help.
04-21-2011, 08:19 PM   #3
Thanks HCC!
04-21-2011, 08:26 PM   #4
Now that I tink about HCC's answer I think I was misunderstood. To claify, what I am looking for is the distance the flash housing overhangs the lens.
If looking down on the top of the camera how far is the flash enclosure extending past the base of the lens (lens mount)?
04-21-2011, 11:31 PM   #5
RichardS's Avatar
Allowing for sighting errors, around 10mm. Could it really be half the distance of a K20D? Hmm. Looking down vertically with a steel rule butting agains the lens mount and sticking out along the axis of the lens. Yup. The steel rule starts at zero, so I didn't make that mistake
Richard.
04-22-2011, 04:33 AM   #6
QuoteOriginally posted by Hornet Quote
Precisely 8mm
04-22-2011, 06:06 AM   #7
HEEGZ's Avatar
QuoteOriginally posted by Schraubstock Quote
Precisely 8mm
I agree, it is 8mm. The link below has the full-size image, reduced-size image in my comment:
K-7 Flash Overhang is 8mm | Flickr - Photo Sharing!
04-22-2011, 08:46 AM   #8
Just checked on my K-5. It's exactly 8mm.
04-22-2011, 08:48 AM   #9
Thanks everyone! Looks like a K5 will work out perfectly for me!
04-22-2011, 12:19 PM   #10
Col
Col's Avatar
Good to hear someone is happy with 8mm!
Come on, that is one of the stranger criteria I've seen for choosing the K-5. You can't leave this thread at that. You do know the form factor is no different to the K-7?
04-22-2011, 12:25 PM   #11
HEEGZ's Avatar
QuoteOriginally posted by Col Quote
I originally thought the same thing until I read the last sentence of his first comment. He wants to be able to turn his old lenses 90 degrees on their tripod mounts. Those tripods must be awfully close to the lens mount...
camera, distance, dslr, flash, k-5, k-5 ii, k-5 iis, k5, lens, pentax k-5
SD Speed Measurement Article dosdan Pentax Camera and Field Accessories 3 10-25-2010 02:12 AM
Measurement required for *ist-DL chromo Pentax DSLR Discussion 3 05-11-2010 04:33 AM
Bokeh Blur Measurement smcook99 Pentax SLR Lens Discussion 3 04-08-2010 02:50 PM
Arca Swiss Flip Lock Measurement wanted castle-of-teck Pentax Camera and Field Accessories 0 12-21-2009 06:39 PM
Help needed robbiec Post Your Photos! 4 06-14-2009 08:10 AM
All times are GMT -7. The time now is 05:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
