05-03-2011, 05:40 PM   #91
Ash
Ash's Avatar
He makes a good point though.
One of the things I have found since I started taking pictures some 40 years ago is that DOF is less relevant than sharpness, and that lenses are often (I would go so far as to say always, but someone would find an example which proves the other 99.99999999% untrue in their eyes) sharper stopped down a little bit.
For me, an f/1.4 lens is more for a brighter screen than anything else.
This, as well as giving a slight edge for low-light focusing, is a definite virtue of having faster lenses. But they are still better stopped down in *most* cases, not just for image quality, but for getting enough of the subject in focus...
I have tried to argue the 'f/1.4 is no great DoF disadvantage to f/2' point before but appreciate that there will always be some who simply desire the thinnest of DoF (such as out A/K 50/1.2 owners who use it at f/1.2 )...
05-03-2011, 06:20 PM   #92
Eruditass's Avatar
Focus out to 20 feet with a normal lens and the DoF isn't razor thin...
Some extreme examples with way shallower than what f1.4 would acheive with the brenizer method (all standard lens optical blur, no T/S or post process blurring):
Ryan Brenizer
Sean Molin
Sharpness from stopping down is another story and I agree.
05-03-2011, 06:33 PM   #93
I often wonder if they are more about making a point than about making photographs.
Quite honestly, most of the thin DOF images I've seen here would be vastly improved with a little more overall sharpness, and accepting a bit more, but probably not really noticeable, DOF.
I think this way, too. I almost never shoot at less than f/2 for this very reason.
05-03-2011, 07:06 PM   #94
Smeggypants's Avatar
QuoteOriginally posted by Siegfried Quote
Dudes, the very shallow DOF is just a photographic tool like.......
Actually in a lot of lighting levels and scenes narrow DOF is the way we actually see things with our own eyes and probably accounts for why it we find it pleasurable or natural.
You don't normally notice it becuase you are concentrating on the subject and your eyes AF as you flick from subject to subject at different distances.
05-03-2011, 07:57 PM   #95
Tommot1965's Avatar
There are indeed a few little niggles that I'm sure Pentax could solve with simple firmware updates - the LED AF-assist in external flash shooting is one, as well as improving low light front focusing accuracy. I'm hopeful they'll come to the party with some of these.
OCD is obsessive-compulsive disorder, an overused term merely to describe in everyday language someone who obsesses over detail, thrives on order and struggles with imperfection. Strictly speaking, an OCD-'sufferer' goes to the extent of having the obsessions and compulsions affect and take over their lives.
Ash
how do you find the Af assist lamp ..when I had my K5 it was inconsistent when it would come on or not ....I found that frustrating ..if pentax fixed that alone I reckon it would make a big difference to the AF abilities in low light .....
05-03-2011, 08:23 PM   #96
QuoteOriginally posted by Tommot1965 Quote
Ash
I fond the AF lamp consistent in 1.02 and below. 1.03 it is inconsistent. This is the same on all 3 K-5s I have used
05-03-2011, 08:34 PM   #97
rfortson's Avatar
QuoteOriginally posted by Christine Tham Quote
Another example, the camera is focused on the scarf of the woman on the right, but her friend on the left - inches away from her - is out of focus - taken on the A135mm at f2.8:
I'm sure it could be argued that creatively this is a bad photo - perhaps her friend should have been focused as well, but I personally really liked the way this shot came out.
The difference in focus between the two women are much more obvious when the picture is blown up, or printed on a larger surface.
Hi Christine, I won't presume to comment on your photographs other than to say that they don't support the OP's claim that outdoors, wide open, the AF stinks. Your shots are perfectly in focus where you intended. That's been my experience as well.
05-03-2011, 11:39 PM   #98
Skymist's Avatar
QuoteOriginally posted by Croc Quote
oh i do close it down a bit, in general i'm very happy with pentax, i got well over 100K keepers from just last few years with pentax gear but seeing how old canon with f1.4 lens had no such problems at all this makes me bit mad, pentax gear is too good to be ruined by issue like this.
That's interesting. Before I got my K-5 I got a Canon 550D with a Canon F/1.4 50mm lens. I had a lot of problems getting the AF to work well with the lens wide open. Eventually I gave the camera to my daughter and got my K-5, plus a Zeiss T* f/1.4 50mm. It focused more reliably with the f1.4 than the Canon, most of the time. Even it was not perfect by any means. So I rely on Liveview a lot, and have worked on training my eye with the viewfinder better. But the point is that the two cameras really gave me the same experience with autofocus on similar fast lenses, except that the K-5 was perhaps a little more accurate (but a bit slower) in all but the dimmest light, at which point the two cameras were fairly similar. All testing done with firmware 1.03.
05-03-2011, 11:44 PM   #99
QuoteOriginally posted by Skymist Quote
Hm . . . . I am not understanding this correctly. Zeiss T* 50/1.4 is manual focus only.
05-03-2011, 11:51 PM   #100
JohnBee's Avatar
QuoteOriginally posted by Eruditass Quote
Some extreme examples with way shallower than what f1.4 would acheive with the brenizer method (all standard lens optical blur, no T/S or post process blurring):.
But wouldn't the brenizer method qualify as post processing? I was under the impression that it was a fancy term for panoramic photography.
Anyways, if that were the case, my tendency would be to consider PP to be a more lucrative approach to sequential frame photography. or... better yet... invest in a 645D and lean on the FOV advantages as an alternative.
Oh and great compositions btw. they really work with the colors and settings!
05-04-2011, 03:51 AM   #101
Ash,
Understood, I feel myself a bit confused I haven't met that term before.
Eruditass,
you made my day. I've studied K-5 manual twice (I love reading manuals, honestly) but I missed that feature there.
Zig
05-04-2011, 04:03 AM   #102
Ash
Ash's Avatar
Ash
I've had no noticeable issues with my LED lamp to date for focusing to relatively close distances (up to perhaps about 8m). It helps the K-5 focus fast and reliably. I haven't had Smeggy's problems crop up to now. But I agree, when the light is questionable and the lamp doesn't light up, it can prove to be somewhat more difficult, but not too much - the K-5 doesn't do badly without the AF lamp in those borderline situations.
Where I would like to see a firmware update, I've mentioned it before, is to permit the AF lamp to do its job even when an external flash is mounted, so as to circumvent the flash's slow and unreliable AF spotbeam function.
05-04-2011, 04:22 AM   #103
I was out today with a 2.8 in low light, sunny day but under the canopy, and the Af only hit 3 times out of 20. I will see if i deleted the photos or not. If not i will post and add a link. Funny the 300mm 2.8 lens will AF all over the place. But the same setting the 500mm 4.5 is spot on. I was going to do some tests today but was to busy. As much as i hate too I agree with Croc.
It is a problem with where it focuses for sure. The larger DOF saves the shots with 4.5 and above but f 2.8 is just useless. At first i thought the same thing. Sigma is the pits, but with the 300 in the service center again. I have to throw up my hands and move on to cannon.. What a shame.
I've been critical about testing. but this is getting just funny how bad Pentax is. For me only I have no choice. It is either switch or not post quality photos.
I've said it before but again. I will not buy another Pentax lens. But will pray for a good camera.
05-04-2011, 06:12 AM   #104
Eruditass,
Those pics you posted are great. Not sure if I got your grammer correct. You meant that you used the Brenzier method for those pictures which gave much shallower DOF than one photo at 1.4 could give, correct? Thanks for posting, I never heard this term before, and looked it up quickly. So, the summary of the method is, if you want a wide shot with shallow DOF, since DOF is shallower at longer focal lengths, use a longer focal length lens and take multiple shots, and stitch them together to get the wider perspective but take advantage of the shallow DOF?
05-04-2011, 06:12 AM   #105
Ash
Ash's Avatar
Gary, under good lighting conditions you're not getting AF to lock on, or is it locking on way off the mark? This is different to what I thought would be happening. Seems to me that the troublesome K-5s have different issues unique to each camera. This will be more difficult to resolve with Pentax, but I'd like to know more about your own situation Gary. You have the Sigma 300/2.8 and 500/4.5 - any other lenses you've test driven on your K-5?
camera, dslr, focus, k-5, k-5 ii, k-5 iis, k5, lens, lenses, pentax, pentax k-5, sigma
Fixing a Pentax AF540FGZ hot shoe. Peter Zack Flashes, Lighting, and Studio 24 09-03-2019 01:20 AM
Fixing ZX-5n GerryL Film SLRs and Compact Film Cameras 2 03-08-2011 10:41 PM
Help fixing this Pentax-M 50mm F2 protocold Pentax SLR Lens Discussion 3 08-13-2009 07:23 PM
fixing signature oatman911 Site Suggestions and Help 3 06-25-2009 09:00 AM
Fixing Times Venturi Film SLRs and Compact Film Cameras 11 05-04-2009 02:20 PM
All times are GMT -7. The time now is 11:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
