02-25-2014, 08:17 AM   #601
Fat Albert's Avatar
QuoteOriginally posted by DogLover Quote
I find that weird. I've never had an s-screen to alter metering at all. Every Pentax body I've had for at least the last several years has under-exposed anyway (especially with Zeiss lenses), and installation of the s-screen didn't change that. As a RAW shooter, I don't even bother to dial in an adjustment, though. I've learned that it usually isn't such a bad thing and takes one second to account for in Lightroom. If I'm shooting in a particularly dark environment with no flash I'll dial in a little adjustment.
It's frustrating, and I'm hoping that it's an error on my part that can be corrected. I'll post some comparison shots of a controlled environment later this week and hopefully someone can get to the bottom of this. I have neither the time nor the means to post-process every photo I take, so I depend on good in-camera JPEGs instead. I've been using my K-01 more than I'd like to, given how great the focusing screen works with my manual lenses.
02-25-2014, 08:23 AM   #602
I believe the original poster talked about the metering and how it was more consistent with the s-screen early in this thread? (i.e. as a pro, not a con) That's actually one of the reasons I bought one, although I haven't done any controlled before and after tests. In any case, I believe the screen used DOES affect metering. Maybe that is why I don't have any trouble with metering in Av mode when using stop-down m42 lenses -- everyone always says it doesn't work very well but it works fine for me.
02-25-2014, 10:04 AM   #603
What model camera are you using?
02-25-2014, 10:43 AM   #604
QuoteOriginally posted by marcusBMG Quote
original K-5
02-25-2014, 03:53 PM   #605
My K-r is hopeless. Had some better results recently with a plated brass rimmed M42 adapter that didn't seem to provoke any flopping and exposure compensations were more reasonable ~ +1eV
02-25-2014, 04:33 PM   #606
Some screens absolutely affect metering, particularly split-screens, I just haven't found the s-screen to.
---------- Post added 02-25-14 at 05:35 PM ----------
QuoteOriginally posted by Fat Albert Quote
K-01 actually doesn't have a focus screen since it doesn't have a VF. No wonder it works so well, huh?
02-25-2014, 05:07 PM   #607
I haven't done tests, but I believe the guy that was originally advocating for it did and found it was more consistent. I remember that being a factor in my decision to get one.
Think he was saying he ought to be using the K-01 less since his other body has the focusing screen in it and he'd rather use that one for manual lenses...
02-25-2014, 05:59 PM   #608
Fat Albert's Avatar
Yep. I may be a novice but I'm not a total moron
03-04-2014, 09:12 PM   #609
Just put my ee-S screen in. Took five minutes and it seems I don't need shims. Phew! The viewfinder is a little darker but manual focusing is much, much easier. Seems the experiment has succeeded.
03-05-2014, 12:33 AM   #610
noelpolar's Avatar
QuoteOriginally posted by maxxxx Quote
Good news….mine was posted a few days ago………….
03-05-2014, 07:34 AM   #611
It is easy to get fooled but since the stock screen and the new screen are different thicknesses you *should* need shims unless your stock screen was already miscalibrated in just the right direction. Put the fastest lens you can find on it (f/1.4 preferably) and try critical focus at close distances -- you'll probably find you need to shim it...
03-05-2014, 09:50 AM   #612
True, unfortunately. Although, my K-3 did not need shimming and I tested it as critically as I could at f/1.4. Both my K-5's and my K-7 did need shimming.
03-05-2014, 10:23 AM   #613
chickentender's Avatar
Which screen exactly did you order? I've a Katzeye split-focus in my K-3 currently, which is better than stock but still leaves me wanting a bit.
03-05-2014, 10:49 AM   #614
Good point. I have only tried a 105/2.8. I'll try my 50/1.7 tonight.
The focusing screen shouldn't have an impact on autofocus, or does it?
03-05-2014, 11:06 AM   #615
It does not impact AF.
camera, dof, dslr, exposure, f1.4, f3.5, fa50, focus, folks, k-01, k-3, k-5, k-5 ii, k-5 iis, k5, katzeye, lenses, love, pentax k-5, photos, screen, shot, split
Canon ee-S focus screen, anyone? dlacouture Pentax Camera and Field Accessories 2 04-30-2011 01:22 PM
Some Bird Shots - Manual focus with Canon 'Frankinlens' on K10D gscara Post Your Photos! 10 04-09-2011 05:16 PM
K-x manual focus screen? nixcamic Pentax DSLR Discussion 1 12-07-2009 10:45 AM
Manual Focus on Pentax DSLRs - I want my split prism screen PentHassyKon Pentax DSLR Discussion 17 02-22-2009 04:42 PM
Do we require split screen for manual focus? madhurvyas Pentax DSLR Discussion 32 07-23-2008 03:51 PM
All times are GMT -7. The time now is 04:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
