Show Printable Version 399 Likes Search this Thread
10-30-2012, 01:24 PM   #181
mattb123's Avatar
I used my A*300 on an old Vivitar 2x TC to get these shots of the Venus transit last summer with my home made solar filter.
I really wanted to get a little context too so I tried to get a little relative foreground in there. That proved to be a challenge.
This is my stylish looking filter
10-30-2012, 01:50 PM   #182
QuoteOriginally posted by ibbe Quote
Hi m8,after bougth the gps1 and download the firmware I have managed to take great astropicture, But it seem that SR wont work again then gps is off, so that to do to get a working SR back?
I have never heard about that kind of error.
  • What camera body do you have?
  • What firmware version have you installed (press the menu button while you turn your camera on to confirm)?
  • What does the SR symbol look like in your view finder (or in the IBFO LCD display)?
  • Can't you re-activate SR in the Recording Mode (Rec. Mode. 4 if your camera is a K-5)?
The latter should not be needed under normal operations unless you have specifically turned SR off, but if it has somehow been turned off, you should definitely be able to re-activate it here.
10-30-2012, 01:55 PM   #183
QuoteOriginally posted by mattb123 Quote
I think you met the context challenge very well! That second shot is just great.
10-30-2012, 04:05 PM   #184
Found the problem,I had the 2sec self timer on and then the SR menu closed.change to normal photomode and everything worked as usual.
10-31-2012, 01:11 AM   #185
@mattb123
Very nice pictures, but is it the infamous string of pearls one can see on the first picture?
10-31-2012, 03:06 AM   #186
Ex Finn.'s Avatar
Nice solar image, shows off the sunspots nicely also. That second image turned out good for a such difficult shot.
10-31-2012, 08:14 AM   #187
mattb123's Avatar
Thanks you guys! I was really scrambling for the second one to try and get the exposure right and catch the sun in the right place. Took more than a few duds in that session!
Gimbal, are you referring to the sunspots? I'm not really sure which those are but I recall there were some active ones at the time and that was them.
10-31-2012, 08:21 AM   #188
mikeSF's Avatar
you deep sky guys are amazing with you examples! wow.
i still haven't gotten out beyond all the light pollution, but here are a couple of my landscape astrophotography attempts with the O-GPS1 from a few months ago:
that first one was 2.5 minute exposure with minimal trailing and the bottom one was 2minutes. Using the O-GPS1, I find the longest realistic exposure I can get is just over 2 minutes with a wide lens (despite the fact the unit may tell me 5 minutes when i calibrate it - don't count on that).
10-31-2012, 08:29 AM   #189
Yes, are you sure they are sunspots and not sensorspots? I guess you took more then one picture and since the sun "moves" you could compare the pictures and see if the spots follows the sun.
10-31-2012, 08:39 AM   #190
mattb123's Avatar
QuoteOriginally posted by Gimbal Quote
Yes, definitely sunspots and I looked up and matched them to what astronomers were seeing at the time. I just don't recall what they were called.
10-31-2012, 06:19 PM   #191
Ex Finn.'s Avatar
Sunspots for sure, my images from the event show the same spots..
11-01-2012, 12:42 AM   #192
Ok, then there is no doubt. So even the sun has the string of pearls problem, can we get it exchanged?
11-20-2012, 11:20 PM   #193
Newbie stacking question
This is my first attempt at the Milky Way (or any star shots) and I would like to make a Christmas card out of it. This is taken with the DA 12-24 at 19mm, 4500 iso, f4.5, 15 sec. and it is quite noisy. I had to really boost the exposure in post (lightroom 4.2). I see I took 5 shots varying between iso 2200-4500 and f4.5-f5.6 at the same 19mm and same 15 sec. Knowing nothing then (and now!) about darks, flats, bias, etc, all I have is "lights". So my question is: might it be worthwhile to use a program like Deep Sky Stacker (is that what it is called?) and just use the 5 lights? Does it matter that the iso and f-stop varied? I would like to get more into this and this would be my first foray so what would be the best "easy" program to start out? Could I create dark images after the fact that would help?
Also, I took shots of the adjacent part of the milky way with plenty of overlap but CS6 freaks out and won't stitch them. Is there a trick to stitching star shot panos?
Thanks for any suggestions!
PENTAX K-5  Photo
11-20-2012, 11:36 PM   #194
smigol's Avatar
You could always try the mosaic option in DSS under the lights tab. That will give you a merged image that should fit the panorama. The projection over a large area will not have as much fine control like you would get on panoramic software, however.
11-23-2012, 11:34 PM   #195
stacking program for MAC
I was hoping to use Deep Star Stacker but I see it is only for PC's. what is recommended for MACs?
I tried Astrostack but couldn't get it to work
thanks
activations, angle, camera, dslr, flickr, gps, images, interval, k-5, k-5 ii, k-5 iis, k5, lake, leds, lens, pentax, pentax k-5, picture, shutter, sky, star, thanks, time
Astrophotography iClick Pentax DSLR Discussion 1248 12-19-2021 05:07 PM
Astrophotography with Kr??? kooks Pentax K-r 5 04-23-2011 07:12 AM
Astrophotography Naturenut Troubleshooting and Beginner Help 4 09-09-2010 07:27 AM
Astrophotography with K10 J-Rod Photographic Technique 5 12-12-2009 06:08 PM
K7 And Astrophotography Christopher M.W.T Pentax DSLR Discussion 49 11-25-2009 08:51 AM
All times are GMT -7. The time now is 09:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
