03-21-2014, 11:27 AM   #616
Hello Seti
Do you acquire your photos on the SD card of the K5, or on a computer you link to the K5 ?
I used to run Pentax Remote Assistant with my K10 to acquire directly on a laptop, but will it work with a K5?
Thanks
03-21-2014, 11:39 AM   #617
Astroboy69
I use pkTether (PK_Tether | Tethering and remote control software for Pentax DSLR cameras). That way I can have the pentax k5 set to bulb and let the computer control the exposure length and shooting interval. then the raw files just upload to the computer in real time. Then you can have programs like DeepSkyStacker Live monitor the folder and real time register the files as they are being captured.
Thanks
03-21-2014, 02:11 PM - 1 Like   #618
Thanks Seti
I installed it just right now, and it works just fine!
Thank you
03-23-2014, 07:15 PM   #619
Awesome! Remember you can't use live preview on the camera when hooked to pktether. I usually do all my aligning first with live preview. Then hook it up to pktether to do imaging. I ran into problems trying both at once. Usually had to pull the battery out to do a hard reset on the camera.
03-24-2014, 01:53 AM   #620
ok, thank you for the advice i'll try not to play with live view once i plug it in
03-26-2014, 07:46 AM - 2 Likes   #621
M1 Crab Nebula
13 x 600"
ISO400
Pentax k5
Celestron C8 SCT, NEQ6 Pro mount, OAG with ASI120MM, Meade LPR Filter
03-27-2014, 04:59 PM   #622
03-31-2014, 11:08 PM - 1 Like   #623
Fisheye lens' star party
Not pro astrophotography pictures but I wanted to share just a couple shots with the Pentax Fisheye zoom lens.
From Lake Huron, still frozen! It was pretty cold! Alignment is not perfect and light pollution was pretty bad too.
Best,
sebastian
04-26-2014, 09:06 AM - 1 Like   #624
Open Cluster M67
Open cluster M67. Probable cluster our sun came from. Photographed from my backyard
Celestron c8 at f6.3 mounted on neq6 pro
Pentax k5, ISO800, 120" exposures through meade lpr filter
04-26-2014, 09:36 PM   #625
testing a new coma corrector
I bought a Baader Multi Purpose Coma Corrector (MPCC) for use with my Orion 8" f3.9 astrograph. The scope has a lot of coma, as expected from a fast Newtonian. The MPCC is designed for DSLR photography with the exact amount of backfocus for a t-ring (other cameras can be used by adjusting spacers).
Here's my first shot with the MPCC. Stars remain sharp across the frame so the it did its job. This was just a test without a PC, so I wasn't using autoguiding nor using pk_tether for >30 second exposures.
Target was M101 and some NGC galaxies are also visible.
04-26-2014, 10:21 PM   #626
JimmyDranox's Avatar
The shot looks good. And because I have a 12'' f4 mirror, and I want to built a body this summer for it, I'm very interested. I know there is a MPCC Mark II, and Mark III. What type is yours?
04-27-2014, 07:52 AM   #627
QuoteOriginally posted by JimmyDranox Quote
The Mark III. Let me add that it's designed for astrophotography; visual use requires screwing spacers between the corrector and eyepiece, and each eyepiece needs different spacing.
04-27-2014, 08:36 AM   #628
Thank you John.
05-06-2014, 08:02 AM - 3 Likes   #629
M104 Sombrero Galaxy
30 x 360" exposures
Pentax k5 @ iso800
Celestron C8 on NEQ6 Pro mount
05-06-2014, 08:06 AM   #630
Very good. Congrats.
activations, angle, camera, dslr, flickr, gps, images, interval, k-5, k-5 ii, k-5 iis, k5, lake, leds, lens, pentax, pentax k-5, picture, shutter, sky, star, thanks, time
Astrophotography iClick Pentax DSLR Discussion 1122 07-21-2016 09:18 PM
Astrophotography with Kr??? kooks Pentax K-r 5 04-23-2011 07:12 AM
Astrophotography Naturenut Troubleshooting and Beginner Help 4 09-09-2010 07:27 AM
Astrophotography with K10 J-Rod Photographic Technique 5 12-12-2009 06:08 PM
K7 And Astrophotography Christopher M.W.T Pentax DSLR Discussion 49 11-25-2009 08:51 AM
All times are GMT -7. The time now is 08:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
