12-12-2014, 08:55 AM   #736
fs999's Avatar
My first shots with O-GPS1. I don't know what it is, but was beautiful.
Pointing east.
1600 ISO • Pentax DA 55-300mm F4-5.8 ED • 61.81 sec
More wide.
1600 ISO • Pentax DA 21mm F3.2 AL Limited • 179.83 seconds
Where can I find a good star map on internet ?
12-12-2014, 09:30 AM   #737
TedH42's Avatar
The Pleiades, M45.
12-12-2014, 11:30 AM   #738
QuoteOriginally posted by interested_observer Quote
You are located near Helsinki Finland, if I am not mistaken, which is at 59 degrees North. So the GPS satellites fly up from the south, and essentially turn overhead and head back south again.
Over 60 degrees North But you are right. I don't have GPS satellites over my head or in the north. Glonass would be better for me or if I could rig my camera to use DGPS. I accused my tripod because it is not sturdy enough for my camera and 1 kg objective. At least wind caused some vibrations in long exposure shots. Or it might have been that sea ice I was standing on and moving around my camera while it was taking a picture.
Nice info and thanks for detailed answer!
QuoteOriginally posted by Gimbal Quote
The heading and the angle up/ down however has a large impact on the result. And the electronic compass is tricky, sometimes itís accurate, and sometimes itís not. The heading from the compass is also affected by the angle of the camera.
Stacking is the key to success.
I'm leaning on this. That electronic compass can sometimes be pain in the arse. I try to keep everything electrical or metallic (phones etc.) things as far as possible from the camera. I'm also thinking that my K5 electronic level indicator is little bit off (or my sensor is degree or two tilted). So if that error affects on headings with O-gps then I need to upgrade my system sometime. Now I will go with these and try stacking.
QuoteOriginally posted by fs999 Quote
I'm using google sky map with my phone on site.
12-12-2014, 12:00 PM   #739
fs999's Avatar
QuoteOriginally posted by TedH42 Quote
The Pleiades, M45.
Thank you very much !
QuoteOriginally posted by ErZi Quote
Thank you ! I will have a look
12-12-2014, 01:32 PM   #740
One thing I might try, sometime, is to first take the bearing to the target with an ordinary compass. Then aim the camera and mount a small and very weak magnet on top of the GPS, (or perhaps a strong magnet on a tripod nearby) and then rotate the magnet until the desired bearing shows on the display. I wonder what that will do with the accuracy.
12-15-2014, 06:48 AM   #741
Hi FS999,
saw your post asking about star maps.
the best star map is astrometry.net
You load up your image and it plate solves for you.
Astrometry.net <- upload link
hope you don't mind I took the liberty of doing your two images
Astrometry.net <- your widefield
Astrometry.net <- you closeup
---------- Post added 12-15-14 at 08:08 AM ----------
Unless you are talking about in the field. Than I use SkEye app on my phone or Stellarium planetarium software (its free)
12-15-2014, 09:33 AM   #742
fs999's Avatar
Thank you seti_v2 ! Nice app !
12-15-2014, 03:10 PM - 1 Like   #743
Pentax K5 DA 12-24, f4, ISO 6400, 30 sec exposure. The foreground is illuminated by a passing car. This is lake mattamuskeet, one of the darkest spots on the east coast of America. You can see the double cluster, the Andromeda Galaxy, and one of the many bright Geminid meteors that I saw on Saturday Night.
01-06-2015, 07:08 AM - 1 Like   #744
An attempt at C/2014 Q2 Lovejoy with a K5, a 70mm limited and the O-GPS1. Unfortunately there was also a full moon at same time so details are washed out. The picture is a 100% crop of a stack of 29 exposures at 15sec each.
01-07-2015, 08:56 AM   #745
C/2014 Q2 (Lovejoy) Comet. First attempt at a comet. 28 x 120" guided exposures at ISO400 Pentax k5
01-08-2015, 08:54 AM - 2 Likes   #746
Learjet's Avatar
Comet C/2014 Q2 (Lovejoy) January 8. Near to close approach tonight. 14 x 30 seconds, 8" F4 Newtonian, Baader MPCC MKIII coma corrector, HEQ5 pro unguided, Pentax K-5.
Comet C/2014 Q2 (Lovejoy) January 8 2015 (Kevin) | AstroBin
01-08-2015, 10:05 AM   #747
JimmyDranox's Avatar
Very good. Like it.
01-17-2015, 12:09 AM   #748
QuoteOriginally posted by JimmyDranox Quote
Very good. Like it.
Comet Lovejoy. Taken near Los Angeles. I subtracted the light pollution from the photo to get this shot. Used a Celestron 5i telescope and tracked the comet. The comet was not visible to the naked eye here, so I use the O-GPS-1 and my 40mm prime to spot the comet in relation to other stars and scanned the region with the telescope until I found it.
PENTAX K-5  Photo
01-17-2015, 12:20 PM   #749
QuoteOriginally posted by Eric Seavey Quote
I also live near LA. Can you explain how you subtract the light pollution? What software do you use? I have Photoshop elements and Lightroom.
01-17-2015, 01:51 PM - 1 Like   #750
You take a photo of the subject, and then you move the camera a little such that there are vey few stars in the frame. Then you unfocus the camera and take a photo. In photoshop you take the blurry image and add it as a layer and select difference to reduce the light pollution.
activations, angle, camera, dslr, flickr, gps, images, interval, k-5, k-5 ii, k-5 iis, k5, lake, leds, lens, pentax, pentax k-5, picture, shutter, sky, star, thanks, time
Astrophotography iClick Pentax DSLR Discussion 1122 07-21-2016 09:18 PM
Astrophotography with Kr??? kooks Pentax K-r 5 04-23-2011 07:12 AM
Astrophotography Naturenut Troubleshooting and Beginner Help 4 09-09-2010 07:27 AM
Astrophotography with K10 J-Rod Photographic Technique 5 12-12-2009 06:08 PM
K7 And Astrophotography Christopher M.W.T Pentax DSLR Discussion 49 11-25-2009 08:51 AM
All times are GMT -7. The time now is 12:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
