01-21-2017, 08:18 AM - 5 Likes   #1051
Pete_XL's Avatar
The K5 was out last Thursday night and caught the witch (Witchhead Nebula IC2118) - which definitely looks like it is named
The Witchhead is a reflexion nebula in the Orion constellation lighted by the star Rigel.
37 x 300s @ ISO 200 with a TS APO Tripet 80/480 mm on an AZ-EQ5
01-28-2017, 07:47 AM - 4 Likes   #1052
Pete_XL's Avatar
This is the reflection nebula M78 and its dark dust nebulas in the Orion constellation and in the left Corner a piece of the so called Barnard's Loop that surrounds most of the Orion constellation.
M78 by pete_xl, auf Flickr
The image was stacked from 30 Pictures with the K-5 @ ISO 400, 360s exposure tíme each.
I will give some more explanations later here:It's all in the data - let's dig it out....... - Astrophotography - PentaxForums.com
02-28-2017, 10:14 PM   #1053
SKYGZR's Avatar
Location: Milky Way Galaxy, Planet Earth, Speeding towards the Virgo Supercluster
Also cross posted in the Astronomy Group
Since the latter part of '16 & mostly so far in '17, haven't had any extended clear skies to do much photon collecting. The brief outings w/ the K3ii have been basically all I've been able to collect, so looked back through some of my old data & found some captured w/the K5ii that I hadn't really worked with, so played around with it. Don't have easy access to the # of sub's & exposure time/ISO settings, but "guessing", probably around 30-50, with some & 800 & some @ 1600, & from 120s-480s, as this is kind of my normal routine on a target like this.
Used the SN8 f/4 w/the BaaderComaCorrector V1, & a LP filter (yet can't know/remember for sure if it was the CLS, or SkyGlow,or?)
Had to crop the field more than normal, as the stack used for the "L" layer was different from the one used for the RGB. It's evident in the upper right and a bit lower, as it was a bit tricky trying to line up the layers.
There are (2) versions. The first is "normal" processing (if one can call it that), in PS6..curves,levels,layers,Annies,Carboni's,GradeX,HLVG..all the "normal behavior" for those like myself to yet be a "Pixsiter" convert.
Added to this posting here: Another PENTAX offering - DSLR & Digital Camera Astro Imaging & Processing - Cloudy Nights
03-19-2017, 11:10 AM - 4 Likes   #1054
Pete_XL's Avatar
K5 @ ISO 80 on NGC6888 once more
(cross posted with a similar thread in the AP-Forum)
NGC6888 is called the Crescent Nebula and is an emission nebula in the constellation Swan.
I reedited the NGC6888 data I shot last October with a bit more pp-experience and as another test of the stacking freeware Sequator. The K5 was set to ISO 80(!). Unbelievable what is possible wit that low ISO with the K5! It is against all theory that I read out there.
K5
TS Triplet APO 80/480
17 x 300 s exposure time, ISO 80, F6.0
Stacking with Sequator, PP in Photoshop CC2017, finish in LR CC2015.8
Link to my thread here in the AP-Forum Does anybody know the software sequator? - Astrophotography - PentaxForums.com
04-06-2017, 01:33 PM - 2 Likes   #1055
Pentax K-5 Long Exposure at ISO 80
QuoteOriginally posted by Pete_XL Quote
...The K5 was set to ISO 80 (!). Unbelievable what is possible with that low ISO with the K5 !...
First, sincere congratulations Pete_XL !
I was very sad to spend the rest of my life being the only one to do Astrophotography with the K-5 at ISO 80 !
K-5 For Astrophotography - Page 4 - PentaxForums.com
6 Astrophotos taken in a well lit city at seaside (lots of turbulence) at ISO 80
No Dark Frames, No Bias Maps (Offset Frames) subtracted !
...Unbelievable what is possible with that low ISO with the K5 ! It is against all theory that I read out there...
Not so Unbelievable : the K-5 DR measured at ISO 80 is ~the same~ as the Nikon D600 DR at ISO 100
The (Very) Long Exposure from the K-5 at ISO 80 are the Cleanest RAW files I ever shot !
A 1000 sec Exposure from the K-5 at ISO 80 as is... then Pushed 6 Stops :
https://www.cloudynights.com/gallery/sizes/32054-pk5lv-5-6/large/
PK5Lv 5 6 - Astro - Photo Gallery - Cloudy Nights
...It is against all theory that I read out there...
This is because the first génération of Digital Astrophotographers mostly used Canon Eos xxD CMos Cameras
Their CMos sensors showed Huge Amount of Noise at Base ISO -vs- almost No Noise at ISO 1600
1st Proof here : each Test = 5 subs stacked ISO 100 vs ISO 1600 Same Night & Sky :
M42 : Eos 20d : 100 iso vs 1600 iso - Nebulae - astronomy photos AstronoMike.net
2nd Proof : Canon CMos are NOT ISOless = you CanNot Push an ISO 100 Raw File :
Test Astro 100 iso vs 1600 iso 30 seconds - Nebulae - astronomy photos AstronoMike.net
More on the Huge Difference from a Canon CMos to... the Sony Exmor CMos in the K-5 :
K-5 For Astrophotography - Page 2 - PentaxForums.com
Canon Eos 20d and 5d at ISO 1600 : Members - Astronomy photos
Pentax K-5 at ISO 80 : Members - Astronomy photos
geo444: Galleries: Digital Photography Review : Digital Photography Review
... see you soon... at ISO 80 ?
04-06-2017, 11:09 PM   #1056
Pete_XL's Avatar
QuoteOriginally posted by geo444 Quote
Yes we'll see us ! But at the moment during the galaxy season I do the most images with my K3ii at ISO 400 and ISO 800. I often intended an own serious test between high/low Iso and the K3ii/K5 but imaging time under the stars is so rare and precious that I use every single second for shooting instead .
04-08-2017, 10:00 AM - 2 Likes   #1057
Pete_XL's Avatar
So here I am with the K5 again....
This image is from April 2016 and was a test with the Sigma 70-200 on the K5. I never processed it because of the ugly stars (astigmatism!) but why should it mold on the hardisk?
I will try to get the Veil Nebula once more this year with the K3ii and the SMC Pentax-M 200/F4.0 to see the difference.
05-11-2017, 05:03 PM - 4 Likes   #1058
Another shot using my K-5 camera. Prime focus on a Skywatcher MN190 telescope. Enjoy!
Cigar Galaxy (Messier 82) and Bode's Galaxy (Messier 81)
05-11-2017, 05:14 PM   #1059
mikeSF's Avatar
QuoteOriginally posted by Eric Seavey Quote
very nice!
05-15-2017, 08:02 AM - 3 Likes   #1060
Melotte 15
Melotte 15 in h-alpha and o-iii.
Celestron c8 telescope. Kolari vision modified Pentax k5. Homemade dslr cooler. Processed in StarTools and Photoshop
05-17-2017, 12:41 PM - 2 Likes   #1061
Managed to get out last night and nabbed M101 the Pinwheel Galaxy. Really my first decent galaxy image, just moved and i think the sky is a bit dark here.
Link to the image:
05-19-2017, 01:21 AM   #1062
Pete_XL's Avatar
@ seti_v2: Very nice images! Congratulations!!
Could you explain your Ha and OIII setup with the K5? Where/how did you get yout K5 modified?
Pete
05-19-2017, 04:07 AM   #1063
I had the camera modified by Kolari Vision, they removed the hot mirror and put in just clear glass. Then i can just use narrowband filters like using any astro camera. For halpha i extract the red channel and process that, oiii i process the green channel. Then for things like galaxies i have a baader skyglow filter which kind of acts like the cameras old hot mirror.
05-19-2017, 04:20 AM   #1064
Pete_XL's Avatar
QuoteOriginally posted by seti_v2 Quote
Thank you for the information. I just saw they offer a service in Europe for Pentax and charge minimum 350$ for the conversion. I'll have to think about it a bit of a while......
05-19-2017, 09:18 AM   #1065
very nice Seti_v2
What size filters (diameter) did you use and where did you attach the filters, to the T adapter or the scope focuser. I have the K5 which I don't use to often, and a K01. I see they also convert the k01, I wonder how that would be for astro photography with my 127mm scope. Thanks for the info about Kolari Vision. How long did the conversion take?
Hank
activations, angle, camera, dslr, flickr, gps, images, interval, k-5, k-5 ii, k-5 iis, k5, lake, leds, lens, pentax, pentax k-5, picture, shutter, sky, star, thanks, time
Astrophotography iClick Pentax DSLR Discussion 1218 11-02-2020 08:28 AM
Astrophotography with Kr??? kooks Pentax K-r 5 04-23-2011 07:12 AM
Astrophotography Naturenut Troubleshooting and Beginner Help 4 09-09-2010 07:27 AM
Astrophotography with K10 J-Rod Photographic Technique 5 12-12-2009 06:08 PM
K7 And Astrophotography Christopher M.W.T Pentax DSLR Discussion 49 11-25-2009 08:51 AM
All times are GMT -7. The time now is 02:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
