05-10-2011, 05:23 AM   #1
Tamron-F Pz-AF MC4 1.4x Advice needed
I got a Tamron-F Pz-AF MC4 1.4x for Pentax -- and it will not work with my K5 and DA*300mm f/4 lens. It works with my 100mm WR macro but not the 300. Anyone else have this TC. I understood it would work with the DA*300.
When I install the TC and the 300 -- the battery indicator shows full with noting else on the display. When I push the focus button the battery indicator goes to empty and blinks. I do hear a quick sound from the SDM. Looks like it not making a connection to the power source. But, with the 100mm all is well.
Any advice or anyone with experience with this TC would be helpful
05-10-2011, 05:27 AM   #2
dgaies's Avatar
QuoteOriginally posted by pastorbbc Quote
I have both, and the combination should work (albeit with less than optimal AF performance). I've never run into what you are describing in terms of the battery/power issue. I would also suggest checking and cleaning the PZ contacts to make sue that it's not something simple.
05-10-2011, 06:18 AM   #3
Where are you attempting to use it? In anything but optimal light, it will hunt, if you are lucky. Outdoors in good light it will work, but still may mis-focus even in optimal conditions. Have you tried using it in liveview? I've found the 1.4x and 2x both work much better (though still not perfect) with my 50-135 and also sigma 120-400mm (both use the power contacts for the focus motor; the sigma won't work outside of liveview) using liveview.
It works without issue with the 100mm macro because it uses the screwdrive.
05-11-2011, 03:25 AM   #4
AdrianM's Avatar
I also have the combination of K5, DA*300 f4 and Tamron 1.4x Pz TC. It works perfectly including (and quite surprisingly) autofocus in much lower light than I would have imagined possible. I also have not observed any problems like you have described using the equivalent 1.5x Kenko TC, nor have I observed those problems with other SDM lenses.
05-11-2011, 11:02 AM   #5
Thanks -- I bought the TC off ebay. I've cleaned the contacts -- nothing works. Is there a Tamron -f PZ and a Tamron PZ without the -F? Mine is a Tamron -F -- When I cut the camera on it shows the full battery -- then I hear what sounds like a SDM focus and the battery indicator starts blinking and shows empty. There is nothing else showing other than the battery indicator -- you can't turn on live view or go to a menu. Without the TC the DA*300 works perfectly. Guess I got took on ebay.
Thanks
05-11-2011, 11:07 AM   #6
dgaies's Avatar
Thanks
It sounds like you have the right TC, but something isn't right as what you're describing certainly isn't normal.
05-11-2011, 12:11 PM   #7
philbaum's Avatar
I have the same combination and it works fine. Clean the contacts again. If that doesn't work, i suggest you take into a camera repair shop and see if those pz contacts need adjusting. There might well be a slight tolerance distance difference between the two lenses you are using.
05-11-2011, 12:51 PM   #8
what do you use to clean the contacts?
1.4x, 100mm, battery, camera, dslr, indicator, k-5, k-5 ii, k-5 iis, k5, mc4, pentax k-5, pz-af, tc
Wanted - Acquired: TC - Tamron Pz-AF 1.4x MC4 tophersurlenet Sold Items 3 01-27-2010 08:14 PM
DA*300+Tamron 1.4 Pz-AF MC4 T.C. gdog Pentax SLR Lens Discussion 7 09-28-2009 03:17 AM
For Sale - Sold: Tamron-F 1.4X Pz-AF MC4 Teleconverter (TC) AlexL Sold Items 8 06-24-2009 03:20 PM
Advice needed; Tamron versus Sigma siric Pentax SLR Lens Discussion 16 07-17-2008 05:48 PM
All times are GMT -7. The time now is 01:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
