05-10-2011, 10:31 PM   #1
ISO Button customization
Hey all, new user to the forum, although I've been reading for a while. Just got a new K5 and had a question about customizing the controls.
Old camera was a K10D, and the button sequence to change the ISO setting was hold "OK" and move the front e-dial.
On the K-5, you press the "ISO" button and the move the rear e-dial. Is there any way to switch that to the front e-dial? I've really gotten used to the front dial on the K10, and would love to be able to keep using it.
Thanks,
-Jeff
05-10-2011, 11:01 PM   #2
Not sure which finger you are using, but it would be hard for me to use my index finger to hold the ISO button and change the front dial. Are you shooting in manual mode or something? I just set the front dial to be ISO for most modes anyway, so maybe you can do that instead?
05-10-2011, 11:19 PM   #3
wizofoz's Avatar
It all depends which shooting mode you are in. For example, I have shutter speed on the front dial and aperture on the rear dial in P and manual modes, for example. In AV mode I have AV on the rear dial and ISO on the front dial (no need to press the ISO button at all) In TV mode I have speed on the front dial and ISO on the rear dial.
The available options are under settings menu, page 5,'E-dial programming'
05-11-2011, 02:17 AM   #4
QuoteOriginally posted by hawk1500 Quote
You don't have to hold the ISO button, if you just press (and release) it then the dial stays in "ISO mode" until you press the ISO button again. So there are two ways: 1. press and hold ISO button while using the dial; 2. press ISO button, use dial, press ISO button again.
By the way, the EV comp button works the same. It's all in the manual
05-11-2011, 02:43 AM   #5
Ash
Ash's Avatar
Indeed, just customise it as per your preferences on the E-dial customisation menu option.
The ISO button then becomes an OK button replacement for the K10D/K20D, but you still have the ability to change ISO with the front e-dial in Tv, Av and even X modes if desired.
05-11-2011, 06:08 AM   #6
Record menu 5. E-Dial customization. In Av and Tv on mine, ISO is on the front dial. You can set it so it's on the rear as well if you want. The modes that use both dials for other things, M, TAv, etc you're stuck with the ISO button (not that it's a bad thing).
05-11-2011, 02:34 PM   #7
Smeggypants's Avatar
For me: ISO always on rear dial, Av always on front dial - Unless mode dictates otherwise o.e TAv where Front is Av and rear is Tv
05-11-2011, 09:23 PM   #8
Thanks for all the replies. I understand that I can customize the e-dial in specific modes, but the goal was to have the dials always perform the same task regardless of mode, i.e. rear dial always Av, front dial always Tv, and then button-front dial-button for ISO. Specifically for manual mode.
I guess I'll have to get used to the way it is - no big deal. Otherwise love the K5.
-Jeff
05-11-2011, 09:35 PM   #9
Yeah, I don't think you can remap the ISO function specifically. Some day perhaps they will give us a way to map everything. It only took them 4 generations to make the RAW button useful to me.
05-11-2011, 09:41 PM   #10
Ash
Ash's Avatar
E-dial customisation should be able to assign most combinations of functions as you please, except of course where a variable is not applicable, such as ISO in TAv mode...
But of course you can't have the same functions on each camera mode, since some variables aren't applicable:
e.g. Av: Av rear, -- front (obviously can't assign Tv there)
Tv: -- rear, Tv front
TAv: Av rear, Tv front
M: Av rear, Tv front
X: Av rear, -- front... etc.
This is basically how I have my e-dials assigned EXCEPT, I too had gotten used to how the K10D/K20D functioned and preferred to have the above -- filled by ISO. (And I also liked the Tv e-dial in Tv mode to be at the rear instead.) And instead of the OK + front e-dial, it's now ISO button then rear e-dial.
button, camera, dslr, e-dial, front, iso, iso button, k-5, k-5 ii, k-5 iis, k5, move, pentax k-5
I am getting a lot of noise at ISO 800 and ISO 1600.... Abstract Pentax K-5 & K-5 II 19 11-30-2010 10:48 AM
ISO button on Pentax K-7 GSk Pentax DSLR Discussion 12 09-16-2009 05:00 AM
ISO ranges and low iso, techies please look. Gooshin Photographic Technique 7 09-09-2009 07:37 PM
White balance customization question Sew-Classic Troubleshooting and Beginner Help 5 07-05-2009 07:19 AM
Absence of ISO button jumbuc Photographic Technique 27 03-17-2009 09:25 PM
All times are GMT -7. The time now is 03:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
