05-15-2011, 02:31 PM   #1
RubyT's Avatar
has anyone else had this problem?
I updated my K5 to firmware 1.03 and now I can't access the WB/flash/shooting mode menus (or that 4th one). I press the relevant button, nothing happens. I know they worked prior to the firmware update, because I had specifically checked. Has anyone else run into this? Will returning to version 1.01 fix it?
05-15-2011, 03:12 PM   #2
Are you not in AF point selection mode, by any chance?
A long press on OK should give you a beep and switch to the custom menus...
05-15-2011, 03:14 PM   #3
RubyT's Avatar
I was, and that worked! Thank you so much!
camera, dslr, firmware, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Is this a front focusing camera problem or lens problem? Lens tests Metalwizards Pentax K-r 15 03-06-2011 01:24 AM
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 39 11-03-2010 06:02 PM
Anyone have this problem? dankuno Pentax DSLR Discussion 9 12-10-2009 08:00 AM
Need help with problem dankuno Troubleshooting and Beginner Help 11 08-17-2009 02:09 AM
Card read problem K20d. Have you had this problem? rsi1986 Pentax DSLR Discussion 8 12-27-2008 05:25 AM
All times are GMT -7. The time now is 03:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
