Originally posted by philbaum OK, i'll ask the stupid question. If you took a DF image for use later - what kind of software would allow one to remove that noise from the long exposures?
GIMP, Photoshop, or similar. Also probably plenty of one-trick ponies out there to do similar things. You simply need to do a Difference layer between the photo and the DF.
Just be sure you take this using the same settings on your camera and at about the same ambient temperature.
i.e. Shooting out on a cold night, then creating the DF at home the next day won't give as good of results.
