05-25-2011, 12:38 PM   #1
Auto ISO in P Mode?
Hi all -- I finally bit the bullet and replaced my trusty *ist DS with a shiny new K-5. Wow, what a great camera! I foolishly let my girlfriend use it to take some pictures at my daughter's play a few weeks ago and it was all I could do to pry it back out of her hands! (She's already decided that she NEEDS one too!)
On to my question. Does the Auto ISO function work in P mode? And if so, how? On my camera, I have to manually change the ISO when using P, is this the way it is supposed to work? If not, can I change it to Auto? I do have Auto ISO selected in the menu and I've tried various ranges (I have it set to 100-3200 at the moment).
Thanks in advance!
Doug
05-25-2011, 01:20 PM   #2
RonHendriks1966's Avatar
When you push the ISO button and have it selected then push the green button.
After this: either give the camera to your girlsfriend or RTFM
05-25-2011, 03:35 PM   #3
Ash
Community Manager
Ash's Avatar
I went through a phase also of not knowing how to get auto ISO to work for me on the semi-auto modes. Then I realised ISO and WB were independent of any auto settings you may have the camera on, and so need to be told to go to auto separately for this to work.
You will notice that once you've pressed the ISO button the arrow will appear next to the ISO, then pressing the green button you'll get the AUTO lighting up, indicating it's back on, press the ISO button again to lock it in and you're set to go.
05-26-2011, 04:25 AM   #4
Thanks Ash, that worked!
05-26-2011, 05:11 AM   #5
In Av and Tv, all you have to do is push the Green button in order to enable Auto ISO. If you press the ISO button and turn the rear dial, regardless of auto or not, it will go back to Manual ISO.
auto, auto iso, camera, change, dslr, iso, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Auto ISO in manual mode yusuf Pentax DSLR Discussion 37 03-10-2012 05:44 PM
Auto ISO in Av Mode v5planet Troubleshooting and Beginner Help 8 03-30-2011 09:46 AM
ISO and Auto Mode VelvetFoot Troubleshooting and Beginner Help 9 01-25-2011 05:19 AM
K-7: Auto ISO in P mode is finally fixed Edvinas Pentax DSLR Discussion 49 08-18-2009 10:19 PM
auto ISO in M mode? not option? Akcelik Pentax DSLR Discussion 4 03-07-2007 05:38 PM
All times are GMT -7. The time now is 04:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
