05-27-2011, 06:13 AM   #1
Frame rate drop to 3 on K-5 with Flash!!!
Yesterday I joined a wedding photographer who works with NIKON D300 with SB-800 or SB-900 (I did not notice that). I worked with K-5 (of course) and METZ 58 AF1.
One significant thing I noticed is that the frame rate per second of the D300 with FLASH remains very high on my K-5 it dropped to about 3 frames per second .
I worked with 6MP JPEG, Flash was on reduced power - 2 / 3, shutter speed was 1 / 60 to 1 / 100
I tried to reduce the power of Flash to a minimum but still did not change anything ... Still 3 Frame per second .
With flash "OFF' K-5 fired at an incredible pace and beautifully, without that I changed anything except turning the flash "OFF" .
Has anyone managed to get 7 frames per second with flash is working on a K-5?
05-27-2011, 06:33 AM   #2
Was your flash set to p-ttl? If so, that makes the camera spend time on preflashes inbetween exposures. Try switching the flash from p-ttl to auto or manual and see if that makes a difference.
Sincerely,
--Anders.
05-27-2011, 06:43 AM   #3
what ISO and what F did you use?
i have the same combination camera - flash, i will try.
05-27-2011, 06:43 AM   #4
QuoteOriginally posted by asp1880 Quote
Sincerely,
--Anders.
It was on Manual and HS-PTTL and "A"... still 3 Frame per second.
05-27-2011, 06:47 AM   #5
QuoteOriginally posted by ionutmar Quote
ISO - 160 to 320
F-8
thanks...
05-27-2011, 08:45 AM   #6
darrenleow's Avatar
QuoteOriginally posted by LEON Quote
ISO - 160 to 320
F-8
thanks...
That aperture-ISO combination seems to be quite demanding on the flash, perhaps the delay is from the flash recharge rather than from the camera? Try shooting at a higher ISO and/or larger aperture and see if it speeds things up?
05-27-2011, 08:53 AM   #7
QuoteOriginally posted by darrenleow Quote
I already tried that. both on manual (with most reduced power on the flash) and on auto. still 3 Frame per second !!!!
05-27-2011, 09:04 AM   #8
RonHendriks1966's Avatar
I noticed that too, it was already with K-7 so the case. It actually is 2.9 fps and that is excatly the same as with K10D, so there is some limitation within the electronic system. If you use something like Cactus then you can maintain 7 fps with off camera flash.
No idea how it is with Pentax flash, but with firmware 1.01 it didn't worked different.
https://www.pentaxforums.com/forums/pentax-k-5-forum/123952-k-5-x-synx.html
05-27-2011, 12:10 PM   #9
i tested at 1/160 F4 ISO 3200 in Manual, Metz 58AF1 on Auto = 3 fps for 23 consecutive shots
05-27-2011, 02:48 PM   #10
philbaum's Avatar
In the Custom menu is a line item that allows the camera to release the flash before fully charged - would that help?
05-27-2011, 10:13 PM   #11
QuoteOriginally posted by philbaum Quote
no, sorry, that doesn't help ether.
05-27-2011, 10:45 PM   #12
Ash
Community Manager
Ash's Avatar
Looks like it's a limitation.
I've also confirmed it with a Sigma EF-500 Super.
Regardless of drive mode, release during charge or WB in flash settings, the max rate for shooting with flash is 3fps.
05-27-2011, 11:55 PM   #13
Just tried this out for myself on the K-5 and it defaults to 3fps even if the flash is off but on the shoe. Can anyone test to see if this also happens if the PC socket is used? If so this is extremely disappointing for me. I was going to invest in a nice set of mono lights but if I am limited to 3fps shooting with flash then I will not bother.
05-28-2011, 12:12 AM   #14
QuoteOriginally posted by Darkside_Hero Quote
as I said with cactus it works. I have no cable at home to sync, but it did work before after firmware 1.02
05-28-2011, 12:55 AM   #15
Ash
Community Manager
Ash's Avatar
Yes, it seems to also drop to 3fps when something is mounted on the hotshoe, regardless of it being powered on or not.
camera, d300, dslr, flash, frame, frames, k-5, k-5 ii, k-5 iis, k5, pentax k-5, rate
Continuous Shooting frame rate ilt Pentax K-r 6 05-20-2011 04:07 AM
Contest Poll Contest #41 Voting (Frame Within a Frame) Damn Brit Monthly Photo Contests 31 02-19-2010 05:49 AM
Expired Theme Theme: Contest #41, January, 2010 (Frame within a Frame) Adam Monthly Photo Contests 11 01-21-2010 12:33 AM
K-x video frame rate pixel r0n1n Video and Pentax HDSLRs 12 09-29-2009 04:22 PM
K10 set at 6MP... will it have a faster frame rate? slip Pentax DSLR Discussion 14 06-28-2007 04:44 AM
All times are GMT -7. The time now is 08:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
