05-29-2011, 06:12 PM   #1
deadprez's Avatar
TAV - green button P line NOT WORKING
Hi folks,
Any help with this would be appreciated.
When in Tav mode If I hit the green button I am under the impression that the P Line is supposed to change but I do not see anything happen.
I have the following settings in TAv : front e dial = shutter speed, rear e dial = Aperture, green button = P line
Where should it display that the P line has changed if it actually has ?
How would I know what P line i am in ?
05-29-2011, 10:13 PM   #2
Can it be the P Line is to reset ur ISO in TAV mode but not shutter speed and aperture?
05-29-2011, 10:44 PM   #3
QuoteOriginally posted by deadprez Quote
That's not what the green button does.
"P Line" means it will set the aperture and shutter speed to whatever your currently selected "Program Line" says they should be set to for a given scene. Basically it will give you whatever settings switching to P mode would have given, with one crucial difference: in TAv mode, it will always use settings that give you base ISO, no matter what. This is pretty dumb if you ask me (e.g. 0.5s, f/1.4, ISO 80 is not a good way to shoot a night scene). A lot more logical would be for it to give you exactly what P mode would have given you with auto-ISO, but that's just the way it is.
In M mode, it does the same thing, except that it will stick with whatever ISO you've selected.
05-30-2011, 06:29 AM   #4
deadprez's Avatar
So really green button in TAv mode is useless
If i understand it correctly whatever P-line is set for the last time you where in P mode will be selected in TAv but it will drop your ISO to 80.
I was curious why the ISO was dropping to 80 ...
Thanks for taking time to explain this ... big help !
button, camera, dslr, k-5, k-5 ii, k-5 iis, k5, line, pentax k-5, tav
green line and red line on lens dh4412 Troubleshooting and Beginner Help 3 03-28-2011 11:39 AM
Dream feature for Pentax K-7 Green Button in TAv skyredoubt Pentax DSLR Discussion 5 09-13-2010 01:13 PM
K-7 Green line woes are over? cbaytan Pentax DSLR Discussion 4 01-08-2010 06:33 AM
Any green line and green banding on the K-x? raider Pentax DSLR Discussion 3 10-21-2009 02:46 PM
working K-7 "green line" firmware fix Nass Pentax DSLR Discussion 3 09-02-2009 12:37 PM
All times are GMT -7. The time now is 01:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
