Originally posted by creampuff Sorry but before you go off and attempt to hypothesize, do you even have a fast Sigma prime mated to a K-5 to begin with?
If you think that my comments become invalid because I don't own a K-5 + Sigma 85/1.4, that's your prerogative.
I wouldn't be qualified to write a "hands on" report on the above combination, but surely some of the knowledge I acquired with other equipment transfers to this discussion. Do also think that my
AF adjustment hints do not apply to the K-5 because I don't own a K-5?
Furthermore, assuming that what I read about the K-5's focus problems is not just all lies, it seems plausible to suggest a connection.
If you read my posts again you'll notice that I offered explanations without implying that I'm a 100% sure that they apply in this particular case.
If I had a problem with some equipment, I'd prefer the advice from someone knowledgeable about the principles any day over someone who just happens to own the same equipment.
P.S.: You apparently overlooked a question I asked: "How do you explain that the OP's shots of brick walls and other 3D objects are fine?". How do you combine that observation with your theory that the lens needs a recalibration? I'm not saying that it is impossible that the lens needs recalibration but given the fact that it focuses fine on many objects other than faces, seems to suggest that other explanations should be explored as well.
