06-24-2011, 04:52 PM   #46
I can see this being useful to my bird biologist friends. Take a pic of a bird and the GPS and the bearing to it gets recorded in the EXIF. Too bad Pentax doesn't have finer resolution on its distance to subject estimation which would be useful as well.
06-25-2011, 04:01 PM   #47
QuoteOriginally posted by civiletti Quote
This is a clever use of overlapping tech, but it's practicality needs to be demonstrated. A program like RegiStax works well to combine short exposures into a single image. Will GPS controlled sensor shifting do it more easily or better? How long an exposure of, say, the moon at 1000mm will sensor movement permit?
Well, check the specs: the max focal len. could be 800mm, and max exposure depends on focal len. and position. How well it works depends on the accuracy of the measurements. Short exposures could not be enough to capture some light, and even that some movements of the stars can be catched. Other solution is to buy a equatorial mount which is heavier and usualy (more) expensive, plus you need to set it up right to the north to track well. For the moon you don't need tracking, usualy exposure of 1/200 is fast enough to don't see any movement. Anyway the moon/sun has different speed than stars. Interesting if they implement this.
http://sky.ap.teacup.com/eti_forest/
06-26-2011, 04:22 AM   #48
Col
Col's Avatar
QuoteOriginally posted by valy Quote
‰F’ˆi‚‚j‚Œ‚‚
Nice link, those are some nice results, the shots are only 2-3 minutes so that's peaked my interest. The K5 lead me to firing up my old Equatorial mount, which is quite heavy and polar alignment is a bitch.
Light pollution is pretty bad around here (well I'm within a mile of Stansted Airport!). The idea that I can pack something that weighs just 2 ounces, drive to a dark site at the drop of a hat (or turn of the weather) that together with my normal tripod will give me astrotracking for up to 5 minute exposures is exciting.
This was the best I could achieve last night (Same Cygnus region as in your link)
But then again, the K5 high ISO performance is silly This one is just 44s at ISO 10,000. To show the Andromeda Galaxy rising above the roofs, before the clouds came in.
06-26-2011, 05:02 PM   #49
KansasHorizons.com's Avatar
bodies, camera, dslr, gps, k-5, k-5 ii, k-5 iis, k5, movement, pentax, pentax k-5, slr, stars
GPS Pentax DSLR's PHIL RUDIN Pentax News and Rumors 85 06-13-2011 10:51 AM
Sony makes the coolest advertisements? LeDave Non-Pentax Cameras: Canon, Nikon, etc. 8 02-19-2010 08:17 AM
Pentax K-7 GPS module dealrocker Pentax DSLR Discussion 3 02-06-2010 12:48 PM
Do you know why Pentax is the coolest brand? hopey Pentax News and Rumors 17 04-24-2009 09:32 PM
Pentax DSLRS RAW + JPEG, and all DSLRs for that matter. ebooks4pentax Pentax DSLR Discussion 5 10-01-2008 01:59 PM
All times are GMT -7. The time now is 07:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
