Originally posted by Ash Karina, I too was almost sold going for a new one that way until I saw that customs may still get their hands on the camera from a spot check and make you pay import duties on it.
Hi
Photographic equipment (bodies, lenses and what have you) does not attract import duty in Australia. All items over $1000.00 however will be levied with the GST (10%) on the full amount and not only on the amount that is over the $1000.00 mark. So add 10% on all items that are $1000.00 and more including freight (you must add up all items that are in the consignment not just individual pieces) to arrive at your total cost. Also note, the freight component is added to the item(s) by Aust. Customs because they maintain that this makes up the total worth of you import.
So this is the calculation you must make and have to consider if luck is against you.
Greetings
