06-05-2011, 06:31 AM   #1
Did i get a used or refurb K5?
I recently purchased a K5, working flawlessly so far. But the frame count when I received it was over 400 if my interpretation of the file numbering is correct, reading IPG0400+. Also, a card packed with the camera stated it was not a warranty card but a Serial Number Card, advising to store it. The card was cleanly cut at the top with perforations at the bottom as if something it been torn from the card, such as owner's name, address, etc.
The 16-45mm lens that I purchased also is a bit suspect. Although it seems to perform as expected, no focus, sharpness issues, the lens cap was scuffed with oily marks as if a greasy hand had replaced it on the lens before shipment.
Any thoughts anyone?
Thanks.
06-05-2011, 06:40 AM - 1 Like   #2
dgaies's Avatar
QuoteOriginally posted by CDW Quote
Thanks.
The serial number card is normal, there are no warranty cards anymore. The perforations are also normal. The fact that the images start at 400 also doesn't mean much (could be a function of what was on the card last). You should download PhotoME to check the shutter count if you are concerned. The K-5 bodies should come from the factory with a shutter count of zero.
Not sure what to tell you about the 16-45, but certainly from your description it sounds a bit odd.
06-05-2011, 09:27 AM   #3
CDW
Thanks! That helps clarify things.
06-05-2011, 12:11 PM   #4
I would check photome to be certain. Sometimes a previously used memory card will make the file name be higher.
06-05-2011, 12:55 PM   #5
I don't think it's odd for the shutter count to not be at 0 when the camera ships, but 400 might be a little high. Use exiftool (or I guess photome) to check what the real count is.
I've also bought something that's "new" that had like fingerprints or otherwise suspect marks. Did you check the mount to see if it has been mounted before you put it on? I guess as long as it works fine and has no real defects, you would've made it "used" anyway.
And don't buy from this place again?
06-05-2011, 01:13 PM   #6
dgaies's Avatar
QuoteOriginally posted by hawk1500 Quote
True on the previous Pentax bodies, but starting with the K-5 and K-r the shutter count is reset to zero at the factory before the bodies are sent out. In the past, shutter counts between 100-250 were fairly common on new bodies.
06-05-2011, 01:28 PM   #7
CDW
So far, the K-5 is more than meeting all my expectations, still getting use to the differences between it and the 5D2. No complaints other than I wish the video was 1080P/30 instead of 25. I hate the flicker on pans as I'm not into the 'film' look at all.
06-06-2011, 02:21 AM   #8
David's Avatar
My third K-5, very early SNo. was an obvious refurb and came with 1.03 loaded. Clean with a bit of dust in the VF. Works beautifully and I know it was tested by the OZ distributor before shipping. I'm happy.
06-06-2011, 03:19 AM   #9
philippe's Avatar
In a certain sense, a refurbished camera with that low exp. count would be even better than a new one!
At least, a refurbished one is reassembled, checked, adjusted and fine tuned by hand by a trained technician.
I recall that, at the time, factory refurbished mechanical cameras where even better than new and serial assembled ones, who were build by a line of lesser trained technicians repeating the same 'act' day after day.
For refurbishing, there is a little more time to check several steps and the technician is somewhat controlling himself.
So, good luck with you 'new' K5!
BTW, are you 'coming' from a Canon 5DII?
06-07-2011, 05:15 AM   #10
CDW
QuoteOriginally posted by philippe Quote
Yes, a 5D2, L lenses, XSi backup, etc.
06-08-2011, 09:24 AM   #11
philippe's Avatar
Eh, and did you quit with Canon?
06-09-2011, 07:04 AM   #12
CDW
I have sold all of my Canon cameras and lenses.
camera, card, dslr, k-5, k-5 ii, k-5 iis, k5, lens, pentax k-5
Refurb K-5s showing up? Stringmike Pentax K-5 4 03-19-2011 10:23 AM
refurb K20D vs new K-x vincey Pentax DSLR Discussion 17 12-03-2010 03:04 PM
How do you know when to refurb an ME? Johnct Pentax Film SLR Discussion 13 10-31-2010 10:10 AM
best buy k200D refurb mnseawa Pentax DSLR Discussion 10 06-12-2010 10:43 AM
BB K100D refurb in stock VoodooATL Pentax DSLR Discussion 6 02-04-2010 09:37 PM
All times are GMT -7. The time now is 11:22 AM. | See also: NikonForums.com, part of our network of photo forums!
