06-06-2011, 04:08 PM   #1
FA Lens on K-5, did i miss any adjustments ?
This is sure just me being stupid and my lack of knowledge but:
I just bought a used FA 50 f/1.4 lens, mounted it on my K-5 but all i get is a blinking F-- on the screen. Cant adjust anything and the cam wont take pictures.
I'm sure it's just a simple adjustment ...
Ok guys,... who is first to let me look like the total noob i am.
06-06-2011, 04:11 PM   #2
If the lens has an aperture ring, you should move it to A.
06-06-2011, 04:20 PM   #3
works, ... i knew it has to be just a simple thing.
THANKS !!!
06-06-2011, 05:19 PM   #4
jatrax's Avatar
You might also make sure custom function 22 Using Aperture Ring is set to "2". The default is "1". Well it is custom funtion 22 on my k-x, I see you have a k-5 so it might be a different number.
I am not sure if this matters on an FA but the blinking F--- is indicative of having this set to "1" when using a lens that does not communicate. I don't currently have an FA but it works this way on my F 35-135mm.
After it is set to "2" you will still have "F---" but it will not be blinking any longer and you can use the aperture ring to control aperture.
camera, dslr, fa, fa lens, k-5, k-5 ii, k-5 iis, k5, lens, pentax k-5
Kx focusing adjustments? jjhenders Pentax DSLR Discussion 7 05-28-2011 02:27 AM
K-7 AF Adjustments v5planet Pentax DSLR Discussion 2 02-14-2011 08:06 PM
K7 adjustments Snydly Pentax DSLR Discussion 2 01-25-2011 06:11 PM
K5 lens adjustments - How much for your lens? vievetrick Pentax K-5 15 01-04-2011 10:25 PM
What I miss (and don't miss) about my K10D switters Pentax DSLR Discussion 35 01-06-2008 02:51 AM
All times are GMT -7. The time now is 08:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
