06-07-2011, 05:32 AM   #1
More ??? About lens correction & anti-shake
I'm still waiting for another lens that I've ordered to arrive, so I only have the 16-45 F4 available to test the lens correction feature. It seemed to not do a great job of it. I found that CA correction was still better performed in Light Room 3.4. Has anyone else had a similar experience?
I did receive my adapter so that I could use my P645 lenses with the K-5 and that worked well except that anti-shake is disengaged. Unless I've missed something, I can't find a workaround to engage it. That is a bit of a disappointment as I was hoping that it worked with any lens fitted.
Thanks.
06-07-2011, 07:34 AM   #2
enoeske's Avatar
SR does work with any lens. Make sure the SR is on. Turn off the camera and attach the lens. When the camera turns on, it should ask for the focal length of the lens. Thats the SR so it knows how much to compensate.
06-07-2011, 08:35 AM   #3
CDW
The P645 to K adapter does not pass any electrical data so the camera has no way of knowing what the focal length of the lens is. Too bad Pentax doesn't provide for manual input of focal length data when using 645 or 67 primes.
When I attach a 645 lens via the adapter the SR and Input Focal Length options are grayed out.
06-07-2011, 08:47 AM   #4
enoeske's Avatar
My smc 50mm f/1.4 doesn't have any electrical contacts either, but my shake reduction works just fine with it. Just have to input the focal length when i turn it on.
Are you sure you don't have it in a mode that disables shake reduction, like wireless flash or 2 sec timer?
06-07-2011, 10:42 AM   #5
CDW
Thanks, the Aperture Ring mode was on Prohibited Setting. Changing to Permitted took care of the problem.
06-08-2011, 12:09 AM   #6
hcc
hcc's Avatar
QuoteOriginally posted by CDW Quote
Many Pentaxians do prefer to perform the lens distortion correction on computer.
Personally, I perform lens distortion correction with PDCU 4.32, unless I want more accuracy. In the latter case, I use PTLens. PTLens is an excellent dedicated software for lens distortion correction which is worthwhile for engineering and architecture.
PTLens is well regarded and can be recommended. The price is modest:
PTLens
Hope that the comment and experience will assist.
anti-shake, camera, correction, dslr, k-5, k-5 ii, k-5 iis, k5, lens, pentax k-5
K-5 Anti-shake (image stabilization) test Skymist Pentax K-5 & K-5 II 24 03-26-2012 06:25 AM
Broken Anti-Shake results in Focus issues volvomanny Pentax DSLR Discussion 2 01-18-2011 07:33 AM
anti shake on or off w/monopod Lance C Photographic Technique 4 09-26-2010 08:52 AM
K-7 Hightlight Correction & Shadow Correction & Raw Christopher M.W.T Pentax DSLR Discussion 6 06-10-2010 03:32 PM
Anti-Shake/Tripod? CPB.IV Troubleshooting and Beginner Help 3 07-24-2009 10:28 AM
All times are GMT -7. The time now is 04:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
