Originally posted by starstuff The solid plastic door to the USB port of the K20D has been replaced with a flimsy rubbery thing. Why?
You will find the old hinged door with its neat rectangular rubber O-ring, while it was nice to look at, did not provide the level of dust and water protecting quality. The new rubber door performs much better in this regard.
Also, while in the open position the door could more easily be damaged while in action. (Standing proud off the camera body and a swipe in the wrong direction and the hinges are bend. After all the K-5 is an action camera, isn't it?) Again the new setup performs much better here.
People get used to model specific functions after long use. Then when they upgrade mourn over all those familiarities they suddenly have lost or have changed. This is human nature, we all do it. Don't let emotions blind you. New and different ways of design are not always the result of cost cutting. (I know sometimes they are though). In this example, what if PENTAX was confronted with an unrealistically high amount of "door repairs" because of the above mentioned reason ? Solution ? - Rubber door with rubber hinges - problem solved.
Now of course you get used to the new features and learn to like them and when you next update... And so the wheel keeps spinning.
Oh, and when everything else fails to make sens, read the manual. (I promise I'll give it a go next week).
Greetings
