06-17-2011, 04:13 AM   #1
[langtitle=iw]שלום לכולם, מתעניינת ברכישתk-5[/langtitle]
שלום,
אני חדשה בפורום ... נראה שמעניין כאן....
מתעניינת ברכישת k-5
מאד אוהבת צילום אך חדשה בלנסות להבין מעבר, האם המצלמה הזו תספק את הרצון שלי להפוך את זה לתחביב יותר רציני...
האם קל ללמוד אותה
כמובן שאני מתכוונת להשקיע... אז זה לא הפרמטר
תודה מראששששששש:d
06-17-2011, 04:39 AM   #2
Easy to learn, mmmh....
I'd rather ask: "is photography easy to learn?"...
That's the hard part, and once you master the basic notions of photography, the camera itself is just a tool. And as such, some are better than others.
And the K5 is as all other highly specialized and professional tools out there : if you don't know how to use it, you won't get any results... If you have no skills in carving, no matter what kind of chisel you'll get, you'll never make something by yourself...
So, with it's plethora of controls, it'll give you instant access to nearly everything needed while photographing, which is not the case of cheaper camera (thinking dual-wheels and ISO button here).
Is it easy to use? Depends on your personal level.
06-17-2011, 05:40 AM   #3
dcmsox2004's Avatar
welcome !!
have you ever used a digital camera before? many have manual controls, giving one the ability to fine tune a shot for capture... i started with pentax as a film camera... and have had the k100d, k200d, the k-x, and now, graduated to the k-5.... a wonderful dslr...
i also educated myself by reading bryan petersons book about photography.... very easy to read and comprehend... also, the tips and information here in our forum is invaluable... i couldn't be the amateur shutterbug i am without my forum friends...
the k-5, is relatively easy to understand/use..... the menus take a little bit of time to get accustomed to... but the learning curve is not too steep....
i love my k-5 so far.. and have so many choices of using vintage pentax lenses, and the myriad of third party lenses as well...
bottom line.... if you think you are ready to use the best photographic tool pentax has in it's lineup... go for it!! the forum members will be here to help you... 24/7
best of luck, shalom....dave m
06-18-2011, 03:10 AM   #4
תודה רבה (:
06-18-2011, 03:17 AM   #5
תודה רבה רבה, על התשובה המפורטטת
לא הייתה לי מצלמה מהסוג הנ"ל, עד עכשיו אני בעלת מצלמת פוקט
אך מכיוון שזה כל כך בוער לי החלטתי לעלות שלב ולקחת גם קורס(אבדוק את הספר שהמלצתי עליו... תודה) בכדי להבין ולא סתם לקנות מצלמה,
העניין שאני יודעת שהמצלמה הזו הולכת להיות אצלי שנים... אז אני רוצה לקנות משהו שגם אם ייקח לי זמן ללמוד אותה ולהבין אז זה בסדר...
האמת שאני עדיין מתלבטת אם זו המצלמה...
יש מלחמת עולם ביו טיוב, כמו כן היא מעט יקרה עם העדשות (נגיד ואתחיל עם עדשה בסיסית ולאט לאט)
בכל מקרה תודה ןיום נפלא(:
06-19-2011, 03:30 AM   #6
As far as longevity is concerned, you won't be disappointed by the K5...
I had an habit of changing camera every 6-12 months (done K10-K20-K7&Kx in 2 years), but since the K5 (already 8 months ago), I don't feel like I'll be changing soon...
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
בעיית פוקוס מוזרה hopesfallb Pentax K-r 2 06-02-2011 05:14 PM
עדשות ישנות kobi61 Troubleshooting and Beginner Help 3 01-22-2011 03:13 AM
פלאש של ניקון SB22 על מצלמת פנטקס Kx yogibear Pentax Camera and Field Accessories 3 10-31-2010 04:43 PM
פלאש sb 22 ל kx yogibear Welcomes and Introductions 1 10-30-2010 04:03 PM
שלום חברה סוף סוף פנטקס בעיברית yinon Welcomes and Introductions 1 10-19-2010 02:08 PM
All times are GMT -7. The time now is 06:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
