06-19-2011, 12:04 PM   #1
K5 and photoME compatbility?
I don't use photome very often but I just noticed that all of the lens data isn't included. I will give the information of the focal lenght but it doesn't have the information of the lens used ( one example my D-FA 100mm macro wr and another, my Pentax DA 16-45 f4. It will just give the vocal lenght of the that it was used at.
It is also saying that they are M or K lenses being used. This is mainly in the overview section That will give the name of the camera the lenses and vocal lenght along with apreture, ISO. ect.
I would think the K5 would recognies Pentax lenses.
Hasn't PhotME updated its info for the k5.
when I had the k7 I could get all the info of lens and camera in the overview section. No problem except it thought my Sigma 300/2.8 was a DA, F or FA lens.
I'm I the only one that has noticed this or is it just my camera?
06-19-2011, 12:36 PM   #2
PhotoME has not been updated since May 2009...
PhotoME - Exif, IPTC & ICC Metadata Editor
Cheers...
06-19-2011, 12:45 PM   #3
I just installed and ran PhotoMe and it ran an update of camera info at first boot and read a K-5 PEF just fine with all of the lovely data that it produces.
06-19-2011, 02:33 PM   #4
fs999's Avatar
Did you see the camera temperature tag with the K-7 and K-5 ?
06-19-2011, 02:59 PM   #5
Yup...
QuoteOriginally posted by fs999 Quote
Sure does. Here's a full dump from a K-5 PEF:
Camera temps was 26 degree C.
[PhotoME]
PhotoME version: 0.79R17 (Build 856)
[Overview]
File name: C:\Users\Mike Tedesco\Desktop\_IGP0780.PEF
File type: Pentax Camera RAW
File size: 21,449.1 KB
Creation date: 6/18/2011 17:53
Last modification: 6/18/2011 18:29
Make: PENTAX (PENTAX)
Camera: PENTAX K-5
Lens: K or M Lens
Software: K-5 Ver 1.01
Dimension: 4992 x 3284 px (16.4 MP, 3:2)
Focal length: 31 mm (equiv. 46 mm)
Aperture: F2.8
Exposure time: 1/80" (+0.7 EV)
ISO speed rating: 800/30°
Program: Manual
Metering Mode: Pattern
White Balance: Auto
Focus Mode: AF-S
Image Stabilizer: not stabilized
Noise Reduction: Off
Flash: Flash did not fire, compulsory flash mode
[IPTC-NAA data (IIM)]
Application Record Version: Version 3
Date Created: 2011-06-18
Time Created: 17:53:20 UTC -08:00
??? (2:221): 1:0:0:000780
[Image]
Image width: 4992 px
Image height: 3284 px
Number of bits per component: 14
Compression scheme: Pentax PEF Compressed
Pixel scheme: CFA (Color Filter Matrix)
Manufacturer: PENTAX
Image input equipment model: PENTAX K-5
Image data location: 0x0001AD60
Orientation of image: 90° CW (left/bottom)
Number of components: 1
Number of rows per strip: 3284 rows
Bytes per compressed strip: 20642139 bytes
Image resolution in width direction: 300 dpi
Image resolution in height direction: 300 dpi
Image data arrangement: Chunky Format (Interleaved)
Unit of X and Y resolution: inch
File change date and time: 2011-06-18 17:53:20
Copyright holder:
IPTC-NAA metadata: 0x014F1432
Exif IFD Pointer: 0x000001B6
[Thumbnail Info]
Image width: 160 px
Image height: 120 px
Compression scheme: JPEG (old-style)
Offset to JPEG SOI: 0x00019460
Bytes of JPEG data: 6369 bytes
[Additional Image]
Image width: 4928 px
Image height: 3264 px
Offset to JPEG SOI: 0x013CA6C0
Bytes of JPEG data: 1202485 bytes
[Camera]
F number: F2.8
Exposure program: Manual
Date and time of original data generation: 2011-06-18 17:53:20
Date and time of digital data generation: 2011-06-18 17:53:20
Exposure bias: +0.7 EV
Metering mode: Pattern
Lens focal length: 31 mm
Manufacturer notes: 0x0000030C
Sensing method: One-chip color area sensor
CFA pattern: [Blue, Green], [Green, Red]
Custom image processing: Normal process
Exposure mode: Manual exposure
White balance: Auto
Focal length in 35 mm film: 46 mm
Scene capture type: Standard
Contrast: Hard
Saturation: Normal
Sharpness: Hard
Subject distance range: Macro
[Manufacturer notes]
Pentax Version: 70.0.0
Pentax Model Group: Group 1 (DSLR series & Various Optio models)
Preview Image Size: 640 x 480
Preview Image Length: 37855 bytes
Preview Image Start: 0x00008A20
Pentax Model: 0x12e76
Date: 2011-06-18
Time: 17:53:20
Quality: RAW
Flash Mode: Off; Internal
Focus Mode: AF-S
AF Point Selected: Fixed Center
Exposure Time: 1/80"
F Number: F2.8
ISO: 800/30°
Exposure Compensation: +0.7
Metering Mode: Multi-segment
Auto Bracketing: 0 EV, No Extended Bracket
White Balance: Auto
Focal Length: 31 mm
Saturation: Normal
Contrast: Med High
Sharpness: Med Hard
DSP Firmware Version: Ver 1.01.00.08
CPU Firmware Version: Ver 1.01.00.08
Effective LV: 7 LV
Picture Mode: Manual; 1/3 EV steps
Drive Mode: Single-frame; No Timer; Shutter Button; Single Exposure
??? (0035): 12061, 7988
Color Space: Adobe RGB
Image Area Offset: x = 22 px, y = 10 px
RAW Image Size: width = 4928 px, height = 3264 px
??? (003D): 8192
Preview Image Borders: top = 28, bottom = 28, left = 0, right = 0
Lens ID: 8 + 242 + 0 + 0
Pentax Lens Type: DA or DA*
Lens Name(s) of the ID: smc PENTAX-DA* 16-50mm F2.8 ED AL [IF] SDM
Camera Temperature: 26 °C
AE Lock: Off
Flash Exposure Compensation: ±0
Image Tone: Bright
Color Temperature: Not set
SR Result: not stabilized
Shake Reduction (Setup): 7
Shutter Release Half Press Time: 0.6 sec
SR Focal length: 32 mm
Shutter Count: 51
??? (0060): 0, 0, 0, 0
??? (0062): 8
??? (0067): 1
??? (0068): 1, 0
Dynamic Range Expansion: Off
??? (006B): 0, 0, 4, 4
??? (006C): 0, 0
??? (006D): 0, 0
??? (006E): 0, 0
??? (006F): 0
??? (0070): 0, 0
High ISO Noise Reduction: 255
AF Adjustment: ±0
??? (0073): 65535
??? (0074): 65535
??? (0076): 0, 0
??? (0077): 0, 0
??? (0078): 0, 0
??? (0079): 0, 0
??? (007A): 2, 0
??? (007D): 0, 0, 0
??? (007E): 15867
??? (007F): 65535
Black Point: [512, 514, 515, 514]
White Point: [11456, 8192, 8192, 24960]
Picture Mode 2: Manual
Program Line: Normal
EV Steps: 1/3 EV steps
E-Dial In Program: Tv or Av
Aperture Ring Use: Prohibited
Flash Options: Normal
Metering Mode (2): Multi-segment
AF Point Mode: Fixed Center
Focus Mode 2: AF-S
AF Point Selected 2: 32
ISO Floor: 800/30°
Drive Mode 2: Single-frame
Exposure Bracket Step Size: 0.3
Bracket Shot Number: n/a
White Balance Set: Auto
Multiple Exposure Set: Off
??? (0205): 0
??? (0205): 0
??? (0205): 119
AE Exposure Time: 1/78.3"
AE Aperture: Not set
AE ISO: 800/30°
AE Xv: -0.625 EV
AEB Xv: ±0 EV
AE Min. Exposure Time: 1/7723.5"
AE Program Mode: M, P or TAv
AE Extra?: 0
??? (0206): 128
AE Max. Aperture: F0.1
AE Max. Aperture (2): F2.8
AE Min. Aperture: F2
AE Metering Mode: Bit 2?, Bit 3?, Bit 7?
??? (0206): 1
Flash Exposure Comp. Set: +8.5 Ev
??? (0206): 0
Lens Name: K or M Lens
Pentax Lens Type: K or M
Lens ID: 1 + 0
Additional Flags: Not set
Auto Aperture: On
Nominal Aperture Range: F5.6 - F32
Lens F-Stops: 5
Lens Kind / Version (LC0): 5 / 0
Lens Data (LC1): Not set
Distance Code Data (LC2): Not set
K-Value (LC3): Not set
Near Distance Abberation Correction Data (LC4): Not set
Light Color Aberration Correction Data (LC5): Not set
Open Aberration Data (LC6): Not set
AF Minimum Actuation Condition Data (LC7): Not set
Focal Length (LC8): 6.3 mm
Nominal AVmin / AVmax (LC9): F9.5 / F16
mv' nv' Data (LC10): 31
AVC 1/EXP Data (LC11): 78
mv1 Avminsif Data (LC12): 99
AVmin Data (LC13): F1
UNT_12 UNT_6 Data (LC14): 15
Incorporated Flash Suited END Data (LC15): 108
??? (0207): 200
??? (0207): 104
??? (0207): 112
??? (0207): 40
??? (0207): 0
??? (0207): 3
??? (0207): 49
??? (0207): 65
??? (0207): 99
??? (0207): 255
??? (0207): 255
??? (0207): 255
??? (0207): 242
??? (0207): 45
??? (0207): 83
??? (0207): 1
??? (0207): 13, 0, 0, 116, 9, 97, 0, 11
??? (0207): 0, 157, 255, 253, 242, 192, 0, 0, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 112, 123, 6
Flash Status: 1
Internal Flash Mode: n/a - Off-Auto-Aperture
External Flash Mode: 0xF0
Internal Flash Strength: 63
TTL D/A A-ch Up: 0
TTL D/A A-ch Down: 0
TTL D/A B-ch Up: 0
TTL D/A B-ch Down: 0
??? (0208): 0
??? (0208): 0
??? (0208): 0
??? (0208): 0
??? (0208): 0
??? (0208): 48
??? (0208): 32
??? (0208): 166
??? (0208): 0
??? (0208): 0
??? (0208): 0
??? (0208): 0
??? (0208): 0
??? (0208): 0
??? (0208): 0
??? (0208): 0
External Flash Guide Number: Not set
??? (0208): 0x0
External Flash Exposure Comp: Not set (Off or Auto Modes)
External Flash Bounce: Not set
AE Metering Segment 1: 5.4 LV (center)
AE Metering Segment 2: 5.4 LV (center edge)
AE Metering Segment 3: 5.1 LV (upper, mid-right)
AE Metering Segment 4: 5.3 LV (upper, mid-left)
AE Metering Segment 5: 5.3 LV (upper, right)
AE Metering Segment 6: 5.9 LV (upper, left)
AE Metering Segment 7: 6.4 LV (mid-right)
AE Metering Segment 8: 6.6 LV (mid-left)
AE Metering Segment 9: 6 LV (right)
AE Metering Segment 10: 3.8 LV (left)
AE Metering Segment 11: 1.6 LV (lower, mid-right)
AE Metering Segment 12: 5.3 LV (lower, mid-left)
AE Metering Segment 13: 5.4 LV (lower, right)
AE Metering Segment 14: 5.1 LV (lower, left)
AE Metering Segment 15: 5.4 LV (top)
AE Metering Segment 16: 5.3 LV (bottom)
Manufacture Date?: 2011-04-13
Camera has been serviced?: Serviced bit not set (Value: 2?)
Production ID?: 2
Internal Serial Number?: 63243
Power Source: 114 (Flag 7 set)
Battery States: Body Battery: 5; Grip Battery: 1
Battery A/D Body No Load: 2
Battery A/D Body Load: 247
Battery A/D Grip No Load: 2
Battery A/D Grip Load: 215
Number of Matrices: 18 matrices
Matrix 1: [12512, -4352, 32], [-1728, 12832, -2912], [288, -3392, 11296]
Matrix 2: [14015, -4582, -1241], [-2027, 15021, -4802], [-141, -4627, 12960]
Matrix 3: [14333, -4934, -1207], [-2592, 15598, -4814], [-508, -3831, 12531]
Matrix 4: [14397, -5065, -1140], [-2464, 15713, -5057], [-845, -5311, 14348]
Matrix 5: [16225, -6840, -1193], [-2446, 17469, -6831], [-380, -2963, 11535]
Matrix 6: [8831, -611, -28], [-1221, 11035, -1622], [-146, -283, 8621]
Matrix 7: [12940, -5515, 767], [-1361, 13305, -3752], [294, -4961, 12859]
Matrix 8: [6766, 2689, -1263], [-515, 9159, -452], [1758, 384, 6050]
Matrix 9: [12512, -4352, 32], [-1728, 12832, -2912], [288, -3392, 11296]
Matrix 10: [2783, 5826, -417], [2784, 5825, -417], [2784, 5826, -418]
Matrix 11: [757, 8809, -1374], [758, 8808, -1374], [758, 8809, -1375]
Matrix 12: [3380, 5590, -778], [3380, 5590, -778], [3380, 5590, -778]
Matrix 13: [8450, -205, -53], [8450, -205, -53], [8450, -205, -53]
Matrix 14: [10174, -2662, 680], [10174, -2662, 680], [10174, -2662, 680]
Matrix 15: [6946, -275, 1521], [6946, -275, 1521], [6946, -275, 1521]
AF Points Unknown 1?: Center
AF Points Unknown 2?: Center, Bit 13?, Bit 14?, Bit 15?
AF Predictor: -4
AF Defocus: 2
AF Integration Time: 30 ms
??? (021F): 0x1F (31)
AF Points Unknown 3?: Center (horizontal)
AF Points In Focus: Center (vertical)
??? (0222): 8323
??? (0222): 8036
??? (0222): 8061
??? (0222): 8348
??? (0222): 8520
??? (0222): 8438
??? (0222): 7987
??? (0222): 7946
WB BA compensation: ±0
WB GM compensation: ±0
Sensitivity Steps: As EV Steps
??? (0229): 4029027
??? (0231): 0, 0, 0, 0
??? (03FF): , , , , , , , , , ú, , , , ,
06-20-2011, 04:51 PM   #6
As you see in the first section
[ Overview ]
Camera: PENTAX K-5
Lens: K or M Lens
This is what I am speaking of, where it says lens, it should give the name of the lens used at this point.
06-21-2011, 02:45 AM   #7
andre-mz5's Avatar
The extended lens info can be found in the section Manufacturere notes
06-22-2011, 03:39 AM   #8
QuoteOriginally posted by andre-mz5 Quote
I can see that but thats not my point.
Anyway, its not a big deal. I can see now that its not just my camera and as Michaelina2 states " Photome has not been updated since 2009"
camera, dslr, info, k-5, k-5 ii, k-5 iis, k5, lenght, lens, lenses, pentax k-5, photome
Is there a program like/equivalent to PHOTOME for Mac OS X ? brosen Digital Processing, Software, and Printing 16 07-21-2011 11:55 AM
PhotoMe alternative for Mac Ubuntu_user Pentax K-5 & K-5 II 13 05-16-2011 12:10 PM
You can read K-x battery state via PhotoMe or Exiftool rawr Pentax DSLR Discussion 6 11-02-2009 06:38 PM
PhotoME shutter count 230 on 'new' K-7 Markah1 Troubleshooting and Beginner Help 13 09-16-2009 12:17 PM
PhotoME help NaClH2O Digital Processing, Software, and Printing 2 07-27-2009 06:42 PM
All times are GMT -7. The time now is 07:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
