06-21-2011, 03:39 AM   #1
frames per second
Sorry if this has been posted before.
I noticed on the weekend that when I try to shot continously as in 7 frames per second, I noticed that the K5 stopped at aorund 3 frames then paused then took another 3 seconds.
When I first got the camera, it went nuts with the number of frames which I was impressed and got some amazing photos.
Your thoughts are appreciated.
Cheers
Russell
06-21-2011, 03:53 AM   #2
Digitalis's Avatar
If you have lens corrections turned on it will severely curtail the k-5's buffer therefore reducing the Max FPS.
06-21-2011, 05:53 AM   #3
Do you have the latest firmware update? 1.01 oder 02 gave you a huge buffer-space back
06-21-2011, 06:11 AM   #4
Deiberson's Avatar
What format are you shooting in? I could be wrong but isn't the FPS affected by the format? Meaning the camera shoots faster with mid grade j-pegs than raw files.
06-21-2011, 06:26 AM   #5
Takes a 3 shot burst, then pauses? That's definitely the distortion correction or the chromatic aberration correction. Turn them both off and try again.
Sincerely,
--Anders.
06-22-2011, 04:39 AM   #6
Deiberson's Avatar
Not to steal this from the OP, but if I'm running into the same problem and I turn them off, how will this effect my IQ? Or are the default settings for the camera "off" from the factory?
06-22-2011, 05:19 AM   #7
Digitalis's Avatar
QuoteOriginally posted by Deiberson Quote
turning off lens corrections only affects your image quality if you are shooting Jpeg.
06-22-2011, 05:34 AM   #8
Lens distortion is mainly visible with wide angle lenses and straight lines near the image borders, typically indoors. It's rarely a problem outdoors.
Chromatic aberration is mainly visible when shooting at wide open aperture in high-contrast situations. Coloured fringes will show along hard edges.
The corrections will only improve your IQ in the above mentioned situations. They are off by default because they slow the camera down.
Sincerely,
--Anders.
06-22-2011, 06:16 AM   #9
Deiberson's Avatar
So then are my fps effected by what file format I'm shooting? In other words, can I shoot in RAW at 7fps or do I need to select a lower jpeg quality to pull it off without the camera buffering?
camera, dslr, frames, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Say What? K10D at 5000 frames a second? Ben Hunt Pentax DSLR Discussion 19 08-19-2010 02:42 PM
Pentax Kx vs Full Frames seliscan Pentax DSLR Discussion 29 02-02-2010 02:41 AM
Digital Photo Frames Bramela Digital Processing, Software, and Printing 4 11-24-2009 07:05 AM
Anyone building their own frames? philbaum Pentax Camera and Field Accessories 3 10-06-2009 12:08 AM
Photoshop Frames GLThorne Post Your Photos! 2 07-02-2009 06:46 AM
All times are GMT -7. The time now is 10:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
