06-22-2011, 01:49 PM   #1
nezih's Avatar
AF trouble with K5 and old and new DA 50-200mm ED Lenses
Recently I had a problem with my new K5 and DA 50-200mm ED Lenses (I have two of them). After putting this lens on the K5, the camera used to struggle to adjust AF and give out a continuous sound as an indicator. I found this out after trying all the other lenses first. It only occured with that lens. The problem is that when you put the lens on, you twist it until it stops,then you have the problem. The trick is to give it a little backward turn to make it click, then everything is OK! I have no such problem with my K20D though.
I just wanted to post this to save people from distress.
Kind regards, Nezih
50-200mm, af, camera, da, da 50-200mm, dslr, k-5, k-5 ii, k-5 iis, k5, lens, lenses, pentax k-5
Trouble with 35mm lenses on a dslr rachcobb Pentax SLR Lens Discussion 9 02-02-2011 07:27 PM
Trouble with screw Mount lenses golfing rob Troubleshooting and Beginner Help 12 04-13-2009 11:13 AM
Upgrading lenses...having trouble deciding:) jnkinney Pentax SLR Lens Discussion 19 12-31-2008 09:02 PM
Having trouble getting focus confirmation with my M42 lenses mudman Pentax SLR Lens Discussion 8 11-07-2007 10:05 PM
All times are GMT -7. The time now is 01:33 PM. | See also: NikonForums.com, part of our network of photo forums!
