Originally posted by Lance C Does anyone know if Pentax makes a pre trigger cable or if one works with the k5? I am looking to have my pocket wizard trigger either my k7 or my k5 using the other camera and a pocketwizard to snap the shutter. Cannon and Nikon both have this feature and I can't seem to find anything on the Pentax.
Thank you
You can do this with Yongnuo RF-602's. Set one transmitter on the Hotshoe of Camera A, and then attached a receiver into Camera B set to the same channel. However there will potentially be a fractional delay between Cam A and B.
You could even then attach a 2nd RX unit onto the first camera as well (i've done it this way, one transmitter, two receivers) and then use a Transmitter as the remote shutter release for BOTH cameras simultaneously (thus solving sync issues with the two shutters....)
The Hardware to do the above (1 x transmitters, 2 x receivers) is probably $40USD all up... then use your PWs for the Flash side of things as needed
But yes - its all doable with the RF-602's anyway... not sure about the PW's..
