Originally posted by droth33 So after reading these posts, would it make sense to wait a year before moving from my K-7 to a new K-5, as I had planned?
That depends on
- how much you depend on low-light AF accuracy.
- whether Pentax will issue another firmware which really fixes the low-light AF issue.
The latter may not be possible, due to hardware limitations.
Note that the K-5's Achilles heel is not an insensitive AF sensor but an insensitive metering sensor. The latter is used to correct wavelength-dependent AF deviations and when it fails, the K-5 front focuses.
As it is the meter that fails, you'll see the problem earlier with slow lenses (e.g., cheaper zooms, or relatively slow primes like the DA 15/4). Fast lenses allow more light to fall on the metering sensor and will let it fail much later, i.e., in darker conditions.
For many the K-5 will provide more than sufficient AF capabilities, but I'm with Byrd-2020: The K-5 has a fundamental problem that needs to be addressed before one can recommend it without reservations.
