Originally posted by Mapleleaf-Mick My new K5 arrived yesterday. After reading this thread, I am wondering if I should upgrade my firmware or leave it as is. I am hoping that I won't have any focusing problems but from what I am reading, there appears to be a very good chance. Any suggestions? From my signature, you can see I will be using a number of different lenses. DA and otherwise. I am depressed now, I have been waiting a year for this body and now find it has focusing isssues. I am P***** Off.
I have no focus problems and haven't from the start....I will skip the GPS Firmware, I don't need it....just in case it would cause some problem.
My biggest problem with the K5 is that because of its very rocky introduction, it makes you gun-shy....you look for problems that don't exist, and find some that don't exist either. Hoya did little to instill trust, and hopefully Ricoh will not go the same path of secrecy and failed communication with their base market.
My suggestion is to just get the K5 and use it as you anticipate, not looking for every problem that has been broadcast here. It may be hard to do, but as handsome as I am, if I look in the mirror long enough, I can find a flaw...or two. Fortunately, the vast majority of K5s perform flawlessly.
Don't look for flaws and you will be a happier person.....I could probably get all upset if I stared at this long enough to find some little fault, so I don't.....
Well, the hat has a big crack in it....I see that, but that's about it....right?
[IMG]
[/IMG]
