07-15-2011, 10:11 AM   #16
rvannatta's Avatar
QuoteOriginally posted by Jim Radcliffe Quote
I can't take all the credit here as others had suggested it might be battery related.. I just tried to experiment in what I thought would be the most logical way to test the theory.
thanks for your work here. My observations are consistent with yours.
I bought my camera in January and no problems until recently which I had associated with the presences of a freshly charged battery. Like you I have no grip or other external power feed.
it seems that once the 'edge' is off the freshly charged battery the issue
fades. My follow up will be to see if I can quickly manage the issue when
I have to change batteries --- or when ever I encounter the flopping issue
by taking some flash photos with the built in flash to explore the theory
that a few flash photos will quickly take the edge off the battery and 'fix' the issue.
I also need to be conscious of the flash usage issue, because it has been a dreary spring, and it is possible that I have masked the issue that has been there all along by 'testing' the camera with a photo or two after I changed batteries with the flash-- just to see if it was going to work....
Anyhow my 'plan' the next time I encounter the flopping issue is to pop up the
built in flash and force some flash shots on the theory that the relative high current drain of the built in flash may quickly take enough edge off the battery
to resolve the issue....
07-15-2011, 10:16 AM   #17
darrenleow's Avatar
Great test. I agree that it seems to only happen with freshly-charged batteries. Whenever I insert a fresh battery I'm already expecting the camera to act up soon. Gonna send it in for repair soon.
07-15-2011, 10:43 AM   #18
KansasHorizons.com's Avatar
I will see if I can reproduce this but I am 99% sure I was mid battery charge and it had not switched batteries yet.
07-15-2011, 11:05 AM   #19
Great info. Makes me wonder if the battery issues is what caused ultimately my circuit board to get fried?
07-15-2011, 11:08 AM   #20
krebsy75's Avatar
Hopefully nobody is holding their breath that Pentax will admit to a problem.
07-15-2011, 11:17 AM   #21
Jim Radcliffe's Avatar
The question that comes to mind (I used to be a radar tech in the military.. did a lot with electronics and buggy systems Uncle Sam purchased) is this a case of:
A: The battery charger somehow over-charging the battery
B: A bad batch of batteries that actually deliver more juice than is required
C: The lack of voltage or current regulation in the camera which has an effect on the electronics
D: An electronic component that has degraded over time (faulty, Etc.)
Or it might be a combination of all of the above. The fact that the mirror floppiing began five months after I bought the camera leads me to believe that D is the more logical answer. It's all speculation at this point but at least I can now force the issue to show itself on demand with a fully charged battery.
It will be interesting to see what Pentax has to say about the issue. Thus far a number of people haver reported that CRIS has never heard of the problem.
07-15-2011, 11:19 AM   #22
krebsy75's Avatar
Has anyone put a voltmeter on suspect batteries?
07-15-2011, 11:46 AM   #23
report to CRIS
If you are experiencing this problem and waiting to see what is done about it before sending your camera in for repair (as I was). Please call Pentax Customer Care at 800-877-0155 and report/complain about it.
The more they hear about this particular problem, the more likely they will be able to figure out the root cause of the issue.
07-15-2011, 12:31 PM   #24
Docrwm's Avatar
QuoteOriginally posted by krebsy97 Quote
Makes me wonder if the non-OEM batteries or OEM's charged on a non-OEM charger are causing the same problems?
07-15-2011, 12:48 PM   #25
Robert, I've never used anything but Pentax batteries and gear so cannot answer that question.
I quit using non-OEM batteries a few years ago after one of them began to swell after charging. This was for Canon gear.. it wasn't worth it to me to save a few bucks only to have my house burn down chraging a 15 dollar battery.
07-15-2011, 12:56 PM   #26
Docrwm's Avatar
Jim,
I understand completely. However, if the issue is voltage then the non-OEMs may provide another data point in tracking down the cause. An alternative would be the non-OEM chargers, like car chargers, to see if the Pentax branded chargers may be pumping the batteries up a bit too high. This is all why I am a VERY strong believer in AA batteries.
07-15-2011, 01:30 PM   #27
philbaum's Avatar
QuoteOriginally posted by Docrwm Quote
Jim,
I haven't had the mirror flop problem yet, but i've had my K5 for 4 months and this conversation has got my interest.
So i tested my batteries, both 1 OEM and 1 non-OEM and the results are in this post:
https://www.pentaxforums.com/forums/1579642-post159.html
Duh, the testing of those 2 batteries showed that the charger determines the final battery voltage, as it was identical after charging in both the 2 different batteries, e.g. 8.41 volts.
So i think you're right, it would be interesting to test some batteries of any make from a car or house charger to see if the voltage is different than the 8.41 volts I got from my charger. If anyone else has a digital voltmeter other than me, please test your batteries and tell us the final voltage and whether you were using the Pentax charger or a different make altogether.
For several though, it sounds like the problem is not showing up till 4 months later - perhaps there is a wear component to this problem. I wonder how many photographers are using the burst mode who have encountered this problem. Perhaps the burst mode is causing premature wear. Just a question.
07-15-2011, 01:35 PM   #28
LaurenOE's Avatar
I wonder how many flashes it would take for the batteries to settle down. A few flash cycles could quicken the battery drain. I suppose you could up the LCD brightness or do some other power intensive things on the camera if you suspect over charged/topped off batteries.
07-15-2011, 02:36 PM   #29
sounds to me like the battery regulation circuit in the camera is degrading over time due to over voltage, until it has degraded enough that the peak battery voltage is enough to cause issue.
quite common for silicon components to degrade over time, either due to poor quality material or higher than designed operating voltage.
07-15-2011, 03:22 PM   #30
Has anyone got a an AC adapter with this problem to see how the K5 responds.
batteries, battery, button, camera, card, dslr, frames, k-5, k-5 ii, k-5 iis, k5, mirror, pentax k-5, pics, post, shutter, voltage
Night Smoking mischivo Post Your Photos! 8 07-07-2010 12:59 PM
If you found a gun on the street Gooshin General Talk 68 02-16-2010 06:52 AM
"This is not a smoking gun; this is a mushroom cloud," Russell-Evans General Talk 53 11-23-2009 03:38 PM
Crack smoking must be fun. Steve Beswick Pentax SLR Lens Discussion 10 11-04-2009 11:34 AM
How to quit smoking.... MJB DIGITAL Pentax Film SLR Discussion 70 10-30-2009 05:29 PM
All times are GMT -7. The time now is 01:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
