The obivous choice is the 16-50, it's the only weather sealed option in that range. The 17-70 is not weather sealed other than that one seal on the lens mount. Otherwise the new HSM Sigma 17-50 f2.8 is meant to be great but not weather sealed.
But if it's starbursts you want then there is one Pentax lens whose mission in life is to give you starbursts on demand, anything from subtle to nuclear explosions, just dial in the amount and it will deliver
That lens is the DA 15mm limited.
