07-26-2011, 08:30 PM   #1
suncrimson's Avatar
Is the SR really effective? Or I have bad luck...?
Just bought my K-5 and it's really amazing Camera.
But i found the SR in (my) K-5 is not very effective.
Every time i half press the shutter i can see the small hand in the view finder and i even can hear some noise from the inside (same as K7) and when I use LV mode i can feel the sensor is “floating”...
I did some test with 1/20, 1/10 and 1/5 shutter speed, I got several blur picture with SR ON ( i was able to get sharp result from K7 with same setting)
After many test shots i found there is no different between SR on and off.
Does it normal? Or maybe i got a bad copy?
Any help will be highly appreciated.
07-26-2011, 08:50 PM   #2
v5planet's Avatar
I had written up a long reply but then realized you already own a K-7 and have achieved superior results with similar settings.
Even still, those shutter speeds seem extremely long for all but the widest angle lenses to achieve any sort of reasonable stabilization of the image. Are you using similar focal lengths on your K-5 as you did on your K-7 to achieve sharp results at those slow shutter speeds?
07-26-2011, 10:08 PM   #3
Rupert's Avatar
If you make honest side by side comparisons, all things being equal, then there is only one conclusion. But......all things being equal must be strictly followed. It is not uncommon for me to find shots close together with SR to be dissimilar in results...or even with my Sigma 17-70 OS lens.
One thing I have noticed with the K5 is that the speed you can get with the higher ISO greatly reduces the need for SR in many instances.
Like here........I got plenty of speed, thanks to ISO 8,000
[IMG] [/IMG]
Do some testing , maybe the SR is faulty....maybe not? If so,it would be very unusual.
Best Regards!
07-26-2011, 10:43 PM   #4
suncrimson's Avatar
QuoteOriginally posted by v5planet Quote
Hi Thanks for the reply!
Actually I owned a K-7 2 years ago and sold it due to the IQ, I found the SR in the K-7 was very capable when I used 43/1.9 with it, 1/10 was never a problem for me..but now i cannot find the same experience on K-5 (with 43). I really can't feel the difference between SR on and off like i said.
07-26-2011, 10:52 PM   #5
QuoteOriginally posted by suncrimson Quote
Try with video or liveview turned on. It should be easy to see if SR works on the LCD. If you can't see any differences, make sure you don't have turned on features which disables SR. (2 sec delay, flash...)
07-26-2011, 10:54 PM   #6
v5planet's Avatar
To be honest, I've not seen good SR results at 1/10 with my 43+K-7 and typically won't shoot anything slower than 1/30 with it (even that can be dodgy). Are you sure you're not just remembering a few lucky frames from the K-7 that caught the SR well? Hard to really judge the effectiveness of your K-5's SR without having them directly next to each other to compare. I just know in my experience with the K-7 that that stabilization tech only occasionally helps with shutter speeds longer than 1/30.
07-26-2011, 10:54 PM   #7
suncrimson's Avatar
QuoteOriginally posted by Rupert Quote
Best Regards!
Hey, that photo is Awesome! : )
Have no chance to do the side by side comparison since I let my K7 go 1year ago...I just feel strange when I use the SR again because it used to very impressive when I had the K7. Now I feel it does not work at all in my k5...
Anyway, I m not using SR very often and I never lie on it, especially (as you mentioned) we have so good high ISO IQ from K-5, speed will never be a problem (it used to be a problem with K-7
Thanks for your reply! and again that ISO800 photo is really impressive!
07-27-2011, 12:03 AM   #8
I have the same "problem", with my 35mm the SR doesn't seem to do much good. My limit seems to be around 1/20 with that lens, and it doesn't matter if SR is on or off. Perhaps a very slight advantage with SR on. (And I do know how to use the SR properly and it does work in live view.) Maybe I'm to steady or something...
07-27-2011, 12:08 AM   #9
kanzlr's Avatar
SR was a disappointment for me too.
actually, I can shoot slower shutter speeds with the Leica M8 than with the K-5...surprising.
maybe it works better with longer lenses, but really, I do not come lower than 1/focal length if I want consistently good results.
I had a Minolta Dynax 5D back in their day. It too had in-body stabilisation. I remember well that it worked as advertised.
07-27-2011, 03:06 AM   #10
gtxtom's Avatar
I know I've been able to do 1/8" hand held as I was doing that the other night.
07-27-2011, 06:18 AM   #11
I think SR in the K5 is equivalent to the SR in the K7, neither better or worse. I don't find that it helps with really slow shutter speeds as much, because subject movement tends to become problematic, certainly with shutter speeds of 1/10 second.
SR is something that I find gives a couple of stops improvement over normal shooting conditions. Shakier people will struggle more. I think the fact that the K5 has 16 megapixels makes it a little harder to hand hold than the 14 megapixels on the K7.
07-27-2011, 08:54 AM   #12
Rupert's Avatar
I love SR, it does make a difference and occasionally a huge difference, but there are many variables that involve how efficient it may be.
Here at 1/20 hand-held 500mm, SR did wonders, but the light and a little luck, along with steadyhands also played a factor.....SR will not perform true miracles, it will make a good situation better.....but will not compensate for a bad situation. Anyhow, that is my findings.
[IMG] [/IMG]
In my short 5-6 years as a DSLR shooter, or as a camera user in general....what I have learned to be most important in many situations, most in fact, is speed. If you can get speed, you can eliminate two of the biggest problems.......movement and movement.
Fortunately, the K5 allows speed that was previously not possible...gotta love that!
Best Regards!
07-27-2011, 10:28 AM   #13
Designosophy's Avatar
For me, the shake reduction has made a difference with the K-x, K-7 and K-5, even at slow speeds. I have essential tremors and need to use very high shutter speeds without SR. The difference is very noticeable.
07-28-2011, 01:48 AM   #14
SR on k10d i can't remember? then on k20d was fantastic, k7 i can't comment because i just didn't use it enough due to bussy year, now with k5 SR does work but i doesn't make me go "WOW" like the k20d did still it is better then nothing
07-28-2011, 02:07 AM   #15
stanic's Avatar
I really like SR coz I am able to get sharp pictures with 18-55 kit lens, with shutter speeds from 1/30 s to 1/3 s without problems...but it also depends a lot on technique - breathing, way you hold the camera etc...
of course it is not going to work very well at 300 mm and 1/80 s
camera, dslr, k-5, k-5 ii, k-5 iis, k5, k7, pentax k-5, shutter, sr, test
Streets Bad luck Rense Post Your Photos! 4 11-01-2011 12:57 PM
How effective is SR in the K-5? Malake Pentax K-5 12 12-04-2010 09:40 PM
Is SR effective? flyer Pentax DSLR Discussion 55 04-14-2010 11:41 AM
FA 31mm Limited assembled in Vietnam - bad QC or bad luck. Voe Pentax SLR Lens Discussion 64 03-03-2010 05:44 PM
cost effective telephoto 4 newbie BigB Pentax SLR Lens Discussion 14 11-05-2009 03:53 PM
All times are GMT -7. The time now is 10:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
