08-03-2011, 07:40 AM   #16
To echo what others said, the K-5 has a lot more range in the shadows than it does in highlights. If anything, you want to underexpose slightly with this camera, not overexpose. You can see this in action in the K-5 vs. 7D head-to-head review on this site.
08-03-2011, 07:42 AM   #17
DAZ
DAZ's Avatar
For almost all of the history of photography no display method has been able to display the entire dynamic range. The captured image has always need to be compressed to display the image.
DAZ
08-03-2011, 08:37 AM   #18
Rupert's Avatar
I am not a technician, but I do notice that the range is much improved. Not questioning the cause, but how much of this might have to do with better metering? I see a huge improvement in metering, do you? My shots come out better to start with as far as being more even.
Regards!
08-03-2011, 07:36 PM - 1 Like   #19
As others have explained, it's all about capturing scenes with extensive dynamic range: for example, a bright sky combined with very dark shadows. In the following image I had bright sky in the corner. The sun was right behind the rock on the right and the dynamic range was pretty extreme between the bright sky and the dark side of the rock. In the past, I might have tried HDR or ND grad filter, but I couldn't use HDR because of the moving surf and an ND grad filter is difficult to use with a fisheye lens. So I either had to capture this in the camera or forget about it. This is what the image looks like straight out of the camera:
The foreground is very dark, the sky almost too bright. With any other digital camera I've used, you would have serious grain problems, and loss of detail, if you tried to bring back the foreground to normal levels. Not so with the k-5. All the information is there, in the raw file; it just needs to be coaxed back to life in a raw converter like Adobe's Lightroom:
Incidentally, since getting the K-5, I've stopped doing HDRs. Really no need for it any more.
08-03-2011, 08:05 PM   #20
QuoteOriginally posted by northcoastgreg Quote
Good example. Is it better to meter the sky and bring back the foreground or meter the foreground and bring back the sky?
08-03-2011, 08:13 PM   #21
DAZ
DAZ's Avatar
QuoteOriginally posted by Anthony Lee Quote
You can't real recover if you clip so you expose for the brightest part of the scene that you want to keep. If you meter for the sky (and not adjust) the sky will be 18% gray and you will loose some of you DR in the sky. To get as much of the DR as you can you will have to expose the sky a little brighter (don't over do it) and then in PP pull the bright sky down a little and the dark part up as much as you can get with out loose it.
DAZ
08-03-2011, 08:38 PM   #22
Actually, Greg, I prefer the original over the pp'ed one due to the total lack of contrast in the massaged one. Somewhere in between would be perfect.
Jack
08-03-2011, 10:39 PM   #23
Hi
As a demonstration of what we are discussing here, namely dynamic range, it is a brilliant example. I am sure this is what the poster had in mind.
To PP the image so it is a keeper for the album I would have preferred the outcome to look something like this (my personal taste):
Greetings
08-03-2011, 11:17 PM   #24
Yep, beautiful job!
08-04-2011, 04:25 AM   #25
dmort's Avatar
That's some great work! In light room, when editing raw, how do you properly expose the rocks without blowing out the sky? I know you can do that in Photoshop...
08-04-2011, 07:16 AM   #26
You can use the GND tool to selectively brighten part of the image, and also the "fill light" slider. A more effective way is probably creating masks in photoshop, but that takes more time.
08-04-2011, 01:38 PM   #27
dmort's Avatar
I was going to say, I thought that you most effectively could use masks. I guess the GND tool is new to lightroom 3? i haven't spent too much time figuring out what is new between LR2 and LR3. Good tip.
08-04-2011, 08:00 PM   #28
QuoteOriginally posted by dosdan Quote
If the scene lighting is difficult i.e. sunset, with this sensor it's much better to use -0.5EV to -1 EVcomp, to ensure the highlights are not blown at all.
Dan.
I've found this depends to some extent on the lens. My DA 21mm Ltd (pancake) does much better at -0.5EV across the board, but my recently acquired DA 40mm Ltd (pancake) seems to like 0.
08-04-2011, 08:52 PM   #29
QuoteOriginally posted by dmort Quote
Hi
The correction I did is not optimal but was only an indication of what can be done.
It can never be optimal working with an 8bit highly compressed JPG image. You can see this in the artifacts where rock meets sky. You would be blown away by the quality of this image had it been a RAW file correction.
I do not use LR, but in PShop I use layers and curves. RAW file manipulation I do in Bibble Pro and OLONEO.
Greetings
08-04-2011, 09:57 PM   #30
Pretty sure the GND was also there in LR2. The actual name is "Graduated Filter"... it's 2nd from right on the toolbar below the histogram.
advantage, camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, range
645D dynamic range Pål Jensen Pentax Medium Format 9 04-30-2010 09:00 AM
Dynamic Range on the K-x Shahmatt Pentax DSLR Discussion 33 04-22-2010 03:51 PM
K-7 and below average dynamic range harleynitelite Troubleshooting and Beginner Help 9 01-18-2010 01:05 AM
Pentax Dynamic Range LeDave Pentax DSLR Discussion 2 11-06-2009 12:29 PM
High Dynamic Range ve2vfd General Talk 2 09-17-2009 04:03 PM
All times are GMT -7. The time now is 07:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
