08-03-2011, 03:27 PM   #1
Dionisis_K's Avatar
External Flash AF assist Beam
Hi.. I did some low light test shots with my K-5 and Metz 48 and only on body assist beam was on.. Neither of times did the flash's beam went on.. Is it a way to make the flash's beam turned on??
Also i should mention that i was focusing at short distance where the body beam was able to lit.. Maybe on longer distances the flash takes action?
Thanks in advance..
08-03-2011, 06:32 PM   #2
imtheguy's Avatar
You can test it by turning off camera body focus assist in the menu and settin the metz 48 to Sb mode. The metz should then emit the red light only, no flash.
08-03-2011, 08:03 PM   #3
Ash
Community Manager
Ash's Avatar
It may also not come on if the camera has enough ambient light for it to focus without the flash's spotbeam.
08-03-2011, 11:02 PM   #4
Dionisis_K's Avatar
Thanks for the info guys.. I m leaving for vacation and actually i didn't had enough time to search it thourough..I suppose if i turn the camera beam off it will work...But i would like it to be enabled automatically because i think it isn't handy everytime i mount or dismount the flash to change the setting of the body af assist..Maybe i ll run some tests and let you know..
beam, body, camera, dslr, flash, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Focus Assist on external Flash 540gz divarak Troubleshooting and Beginner Help 5 05-30-2010 03:32 PM
Pentax 360FGZ help... Focus assist beam??? Senseriffic Pentax Camera and Field Accessories 3 03-06-2010 02:04 AM
AF assist beam for K10D Nvision_Ink Troubleshooting and Beginner Help 5 06-30-2009 09:47 AM
Shouldn't they invent a focus-assist-beam accessory for the hotshoe? aweir Pentax Camera and Field Accessories 11 04-01-2009 04:52 PM
AF assist via external flash? martin s Pentax DSLR Discussion 4 09-02-2007 01:41 PM
All times are GMT -7. The time now is 04:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
