I have been having some freezing with my K-5 that I bought in March. (Its manufacture date is in January 2011.) However, I have reason to believe that the freezes that I am having are not the same as the freezing that has been commonly documented online. My K-5 has frozen 4 times, and only one of them was when I was shooting many frames in rapid succession (and even then I was not using the continuous shutter mode). The first 3 freezes happened with the v1.03 firmware and the last one happened with the v1.11 firmware.
In all cases:
- The battery indicated full charge, and I have no reason to believe that the indicator was wrong
- I mainly use manual focus and I think that it was in manual focus in all cases
- I was not using the flash
- I was shooting in RAW-DNG
- The exposure mode was Av (I think)
In the most recent case, today, I had just turned the camera on without taking a shot. Upon fully pressing the shutter-release, the camera froze. In the other cases as well, the freeze seems to happen right when pressing the shutter-release. The reason that I think this is that the meter values update before the shutter-release is pressed but not after. As documented elsewhere, the only way to unfreeze is to remove the battery. Other than these facts the freezes have nothing in common and I cannot reproduce them if I try. They seem to be random.
For comparison, I used a K-7 from September 2009 to March when I got the K-5, and the K-7 never froze once. However, I was using an A lens on the K-7 and upgraded to FA lenses on the K-5. The K-5 has frozen using both of the FA lenses.
So my question is: have other people had these kinds of freezes? I have seen comments in these forums to the effect of "all DSLRs freeze sometimes." So is what I am experiencing just "routine" freezing or something that I should have looked at?
