08-08-2011, 01:05 AM   #1
Any ideas on this issue ?
Hi all,
Loving my K 5 ! One issue I have had twice. I use bracketing for HDR, 5 images. I also use the 12 sec timer when doing this. The camera beeps for 12 secs and takes the bracketed shots. The issue is i set up for this as normal, instead of 12 seconds then five shots, it beeps and delays each frame for 12 secs one after another.
I have had to reset the camera twice to original settings to get it to behave as it should. Any ideas on this one?
cheers
Phil
08-08-2011, 01:20 AM   #2
wizofoz's Avatar
G'day Phil.
I tried to get my K-5 to re-create the problem, but several tries with the 12/5 bracket setup all worked exactly as they should. 12 sec delay then 5 shots, one after the other. What other settings were you using?
Wayne
08-08-2011, 01:42 AM   #3
Hey Wayne,
Thanks for the reply ! I have had my K 5 for 3 weeks and it has done it twice. So lots of brackets in between the times it has happened. The only pain is having to re enter favorite settings etc.
No big drama yet LOL.
cheers
Phil
08-08-2011, 01:55 AM   #4
QuoteOriginally posted by philby85 Quote
Hi all,
cheers
Phil
Isn't there a setting that controls if the bracketing should be done with one press of the shutter button or individual releases for each shoot?
08-08-2011, 02:04 AM   #5
wizofoz's Avatar
I was about to ask the same question as Gimbal. Do you have one press bracketing on or off when this problem occurs? (custom menu item 9). Are you using a remote at the time, or just a press of the shutter button? Why do you need more than a 2 second delay?
08-08-2011, 03:26 AM   #6
Not sure if in-camera corrections of various types are enabled when bracketing. Don't have a K5 so don't know.
Lens correction on? Low light noise reduction?
Worth consideration?
beeps, camera, dslr, ideas, issue, k-5, k-5 ii, k-5 iis, k5, pentax k-5, secs, shots
Vivitar MC Tele Converter 2X PK-A/R-PK issue...or no issue? WiseOx Pentax SLR Lens Discussion 7 12-15-2019 05:53 AM
Looking for ideas... rollin General Talk 7 03-31-2011 04:28 PM
Nature processing ideas? JesseDavis Photo Critique 6 05-24-2010 11:28 AM
locations and ideas nuckinfutzracing Troubleshooting and Beginner Help 4 03-06-2010 08:31 PM
Landscape Sunrise at -18C . Your ideas! Deimo Photo Critique 10 12-20-2009 01:13 PM
All times are GMT -7. The time now is 02:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
