08-13-2011, 08:01 AM   #1
Is there a "T" mode? I can't find it...
I want to do some long exposures and I'd like to lock the shutter open for a while. Is there a T mode or just Bulb?
If there IS just bulb, how does one go about making extended exposures?
Thanks!
08-13-2011, 08:19 AM   #2
Digitalis's Avatar
there is only a Bulb setting : B mode on the mode selection dial.
To use it, you need either a IR remote control or an electronic cabled shutter release, without either of them you are limited to 30 second exposures in manual mode...that or you can mount the camera on a tripod and physically hold the shutter button down however I would advise against this, because it would most likely cause unwanted vibrations wrecking your images.
incidentally, the Canon RS-60E3 Remote Switch remote* can be used - if you happen to have one lying around.
The T setting is more commonly seen on large format camera systems these days.
*not to be confused with the Canon RS-80N3 Remote Switch which is incompatible.
08-13-2011, 09:09 AM   #3
You can set the B mode to behave as a T mode but a remote Is required. In fact, the camera is set that way as a default. The remotes are dirt cheap. I think I paid $5 shipped for mine that is similar to the one pointed out above. It is a locking remote however so 'T' isn't really required for long exposures. That setting of the B mode is more useful for the IR remote when you don't want to stand and hold the button.
bulb, camera, dslr, exposures, k-5, k-5 ii, k-5 iis, k5, mode, pentax k-5
Post your "Park Bench" "or "Picnic Table" images tessfully Mini-Challenges, Games, and Photo Stories 1347 1 Day Ago 12:52 PM
Program mode: "Auto" vs. "Normal"? PALADIN85020 Pentax K-5 3 02-13-2011 12:22 PM
Mint "complete set" m42 smc takumars becoming harder to find..and expensive. pickles Pentax Film SLR Discussion 40 07-24-2010 08:47 AM
K7 ... where has the metering "bar" gone in manual mode? jpzk Pentax DSLR Discussion 3 06-25-2010 07:26 AM
For Sale - Sold: [SOLD]SMC PENTAX "K" 1:3.5/28mm (Hard to Find) Curbster54 Sold Items 7 02-26-2010 03:53 PM
All times are GMT -7. The time now is 04:01 PM. | See also: NikonForums.com, part of our network of photo forums!
