08-25-2011, 08:05 PM   #1
an3ony's Avatar
Finally going to pull the trigger on the K-5. Any advice?
So, I'm going to pull the trigger on the Pentax k-5 tomorrow. After all of the shootouts, DSLR comparisons, and different forums, I'm satisfied that I'm making the right choice.
Is there something that you'd wished you got on that first night of having the new rig?
I am aware of the stains but is there a batch of serial numbers that I should be aware of?
Any other thoughts please let me know.
-anthony
08-25-2011, 08:14 PM   #2
anything after 39xxxx is good i believe. i think the first thing i did was figure out what every single button/dial on the camera does, this will be very beneficial in the long run. Also play around with the different dial configuration. And of course, take lots of photos of things that interest you.
08-25-2011, 09:07 PM   #3
EdwardConde's Avatar
Whats the learning curve going from the K-X to the K-5?
08-25-2011, 09:12 PM   #4
3 days tops. went from a k-x to a k5 myself
Again, it comes down to knowing what the switches and buttons on the k5 does in each dial setting. the best part for me was the slow realization that i could take photos now at 3200 whereas before i wouldn't even try to break 800; it is very rewarding.
08-25-2011, 09:45 PM   #5
silverelantra's Avatar
QuoteOriginally posted by Eagle_Friends Quote
S/N 40xxxx still has stain issue (check database)
08-25-2011, 10:10 PM   #6
Ash
Community Manager
Ash's Avatar
Any stains would have been from old stock not sold before the issue was officially recognised and rectified by Pentax.
08-26-2011, 03:44 AM   #7
RonHendriks1966's Avatar
QuoteOriginally posted by an3ony Quote
I think most people would like to have a full battery when leaving the shop, but mostly it isn't.
Have fun with it and just shoot some nice things to play around with it.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, trigger
Help me! Should i pull the trigger?!?! Silverkarn Troubleshooting and Beginner Help 27 08-19-2010 10:06 PM
About to Pull the Trigger on Sigma 120-400 but... [Double Post] flash1100 Pentax SLR Lens Discussion 5 09-09-2009 12:44 PM
Pull Trigger: K20D... jocko_nc Pentax DSLR Discussion 7 12-10-2008 06:42 PM
Should I pull the trigger on the DA*200MM? PentaxKangaroo Pentax SLR Lens Discussion 2 09-22-2008 07:53 PM
I am about to pull the trigger...(last minute suggestions wanted) fannibal Pentax SLR Lens Discussion 28 06-10-2008 03:18 AM
All times are GMT -7. The time now is 05:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
