Closed Thread
09-07-2011, 11:41 AM   #46
lammie200's Avatar
I have to admit...
QuoteOriginally posted by Tony3d Quote
The problem only came up when exiting Liveview. After shooting a shot in Liveview using the TAv mode, rotate the back dial, then press the play button. This seemed to cause my camera to freeze more often than just hitting the Liveview button to exit. Although it did freeze using either method.
I have to admit that I don't use Liveview very often. But why did you rotate the rear dial after shooting the shot? Just guessing, but I would probably press the LV button to exit LV then the Play button to see what I shot. What does rotating the rear dial achieve?
09-07-2011, 11:49 AM   #47
an3ony's Avatar
Well, I went out to take some pictures today again, and again, everything just clicked.
For fun, I bought one of those goofy 20 dollar Holga lenses that have the Pentax mount.
100% plastic, but for a metal screw that keeps the lens from unscrewing completely when focusing. I wonder if I could make a macro lens....
Anyway, I'm just having some fun, some of you lot have your shorts on way to tight.
Post your results! I have a Holga, its really fun to work with but I'm interested in how it's going to translate in the DSLR world. And for the price, its almost to easy to just jump on it just to have it in the old photobag.
09-07-2011, 11:49 AM   #48
QuoteOriginally posted by lammie200 Quote
You can rotate the rear wheel on the preview of the shot to hold it. I did this all the time on my K7. Either way my camera would freeze at random using either method.
09-07-2011, 11:58 AM   #49
lammie200's Avatar
OK...
Good luck with your replacement. Hope that won't happen.
09-07-2011, 02:26 PM   #50
Thanks. I'll keep you posted. This next should be fine.
09-07-2011, 02:29 PM   #51
Neither of those procedures causes my K5 to freeze, glad to say.
09-07-2011, 10:24 PM - 1 Like   #52
loveisageless's Avatar
Lovely...
QuoteOriginally posted by creampuff Quote
Unfortunately there are also some people who take it personally when they don't even own a K-5 to begin with...
To all K-5 and other new camera newbies, my suggestion is don't go starting threads at the slightest notice purporting supposed problems and getting overly paranoid about things before you actually read the bloody manual from start to finish and take the necessary time to familiarize yourself with the camera. If there is really a genuine problem, get it exchanged or send the camera in for service.
It would help to use the search button and read past threads and plentiful posts that may have been discussed earlier at length, instead of starting threads on a whim asking for help or advice just because you don't know wtf is happening. That way, you'll avoid most of the negativity and impatience that might come when newbies pose basic and often stupid questions. As newbies, don't always expect instant answers by posting threads claiming about issues that for the most part might be wholly unfounded or that you probably are not fully aware off. Instead, search judiciously and read up first instead of always expecting to be spoonfed or having your angst reassured. I think it is human nature for others to find this sort of behavior pretty tiring, hence the wall of negativity.
Newbie anxiety is to be expected. When one is anxious, one has a hard time focusing on the manual and if the person is a newbie it might not be obvious what terms they should be using in their search. I think if your dominant response is negativity and impatience with such newbies, a vacation from the forum might help you feel better. I'm sure the newbies would feel better too...
09-07-2011, 10:40 PM   #53
johnmflores's Avatar
Mine's working fine except for the thing behind the viewfinder...
09-08-2011, 05:10 AM   #54
Class A's Avatar
QuoteOriginally posted by loveisageless Quote
That, and I don't think that newbie questions are the real problem. As I understand the OP and other posters, the "problem" are threads about the K-5 losing a lens release button, having the mirror flop problem, freezing up, having a stuck shutter, etc.
Unfortunately no parts of the manual are going to be helpful in such cases.
... a vacation from the forum might help you feel better. I'm sure the newbies would feel better too...
That is something that the complainers about the complainers don't get. They don't have to read the complaint threads. Their forum fatigue is self-inflicted. There is an easy solution -- avoid the complaint threads or take more breaks -- but unfortunately it seems to be impossible for some people to a) acknowledge that their happiness with their camera does not mean that everyone else has to be happy to, and b) respect people who see a benefit in communicating with others about their legitimate problems.
09-08-2011, 05:29 AM   #55
creampuff's Avatar
Thank you for your suggestion but you're completely mistaken to think my response is negative nor impatient. And by the same token, who the hell are you to tell anyone to take a vacation?
09-08-2011, 05:49 AM   #56
dgaies's Avatar
Certainly the included user's manual isn't going to cover the above issues. However, the dozens of existing threads specifically about about K-5 stains, mirror flops, freezing, etc. that actually provie quite a bit of useful information on those topics.
09-08-2011, 06:18 AM   #57
Rupert's Avatar
Personally, I do not find the complaint threads offensive. More informative than offensive. We need to know of failures and defects, even if we don't have them in our own K5. I assume that Ricoh is monitoring these Forums, and if they see that no one has problems, they won't be inclined to step up the QC, likewise, when they see much dissatisfaction, even though it may be a limited number of complaints, it will encourage them to make changes that benefit us all.
The only part that bothers me is that it often appears that the majority of K5's have serious problems....and this is just not factual based on the numbers here and at other sites. It is just unavoidable to get that perception, unfortunately.
Regards!
09-08-2011, 07:32 AM   #58
Blue's Avatar
QuoteOriginally posted by johnmflores Quote
That has been a common problem for me across brands.
09-08-2011, 08:49 AM - 1 Like   #59
Wheatfield's Avatar
This entire forum (and the equivalent at DPR) are little more than complaint forums, so it's pretty hard to not read complaint threads.
Even this thread, which was started as anything other than a complaint thread has been hijacked by people who want to complain.
If people would leave the threads that are not about complaints alone, then you would have a legitimate point to make, but when seemingly every thread devolves to a complaint thread, it's pretty hard to not read them.
This thread, for example, started as a positive thread
By post#5 it had turned into a complaint thread, post#6 turned it into an insult the community thread, and by post#13, it was a lets insult the OP thread, and then it was a pile on the OP thread after that.
In other words, this thread progressed at exactly the same rate as I thought it would when I started it.
I'm not sure if the forum passed the test or failed it, but it's behaviour was very predictable.
It doesn't matter if the thread is a complaint thread or a positive thread, the usual suspects doing the usual things is par for the course.
Post something positive, and you'll get insulted and piled on, just the same way that if you post something negative, you get piled on.
For myself, I'm going to spend another lovely September day shooting pictures with my K5 (a first run camera that works perfectly for me), and I'll try to think kind thoughts for all of you who either can't be happy with your camera or can't bear the thought that another person is happy with their camera.
09-08-2011, 10:19 AM   #60
Rupert's Avatar
Hey, it wasn't all bad, Squirrels had a good time in your thread, and advise that in reality, that is all that really matters!
Regards!
Closed Thread
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Omg! I want one!!!! stormcloud Pentax Film SLR Discussion 13 09-23-2010 02:29 PM
All I can say Is WOW OMG! overkillzone Pentax News and Rumors 29 05-12-2010 12:27 AM
OMG I spent how much ? daacon Pentax DSLR Discussion 82 03-11-2010 05:26 AM
K-x soaked - OMG - Nooooo!!! emmandkev Pentax DSLR Discussion 29 02-24-2010 03:02 PM
Better than politics: OMG, I can't believe it... flippedgazelle General Talk 4 11-11-2009 03:09 PM
All times are GMT -7. The time now is 09:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
