Originally posted by i_trax so there is really NO way to have auto ISO in M mode???
well, I did look everywhere and expected it but still, disappointed!
I do have a lot of M42 lenses ( can use in Av) but still have some old fast zooms in K , bugger!
M means manual, no auto anything. This is a result of the crippled K-mount the bodies now have -- even though the K1000 could do it, the body no longer knows what the aperture is set at with K & M lenses so auto is not possible. You can use the hack to fool it into thinking it is a 'A' lens, but as noted the linkage of A & M lenses is not the same so it still will not set aperture properly, and you have to fool it some more with EV comp, and it sounds like it is not a linear adjustment?
So we are left with green button metering, and you can do some quick calculations to adjust ISO to get shutter speed you desire.
