Originally posted by jerm1386 well the sensor assembly and anything else that moves with the SR system is technically, you're right, not bolted to the frame so it would clunk around a bit when you move it. i can feel it as well when i move or jostle my camera. This is perfectly normal and to be honest if it weren't that way then the SR system would probably not be able to work properly. just don't go around trying to see how loud you can make it clunk :-)
Thus described, we would experience the same so-called "clunking" (although I think the OP has described it better as both an audible and palpable sliding of something) in a Sony Alpha-series DSLR, which
also has in-body shake reduction (and, of course, a "sensor assembly" and mirrors and so-forth), and yet...we
don't.
I'm wondering if some of the SR systems are, in fact, too loose on, say, a small portion of Pentax bodies (say, from rough shipment or poor assembly), but whenever the (very real) problem is described, the vast majority of Pentax owners chime in,
assuming the "clunk" is no more dramatic than what's occurring in their bodies and wrongly assure the complaining minority that the phenomenon's normal and not to be worried about.
