09-08-2011, 10:48 PM   #16
Class A's Avatar
QuoteOriginally posted by Smeggypants Quote
Surely the best way to determine what magnification is 1:1 is to look at the real thing and look at the live view and if they are about the same size then you've got 1:1
That would only be correct if
  1. The lens achieved 1:1 magnification, and
  2. The rear LCD display had the same size as the sensor (it doesn't).
User jerm1386 explained it correctly.
09-20-2011, 02:35 PM   #17
..... and isn't an LV magnification factor for 1:1 giong to change depending on the fiocal length of the lens attached?
Maybe the best trick to do is to make a jpg image with photoshop, with the exact dimensions of the K*5 16mpx images, drawing a 640x480px rectangle at the center of the image, import that image on a SD-card, then, read it with the Pentax screen to check the magnification. I've tried, but i cannot read the jpg file with the camera. It's surely a question of compression rate or methode, i'll try other combinations.
09-20-2011, 06:20 PM   #18
Smeggypants's Avatar
Yeah sorry my bad. I was thinking in terms of 1:1 to real life, rather than the OP's question about 1:1 pixel wise.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, lcd, magnification, pentax k-5
K5 LCD question skyoftexas Pentax K-5 26 04-05-2011 08:08 PM
Magnification Question: Reversed 50mm vs. Raynox 250 twokatmew Troubleshooting and Beginner Help 2 07-18-2010 04:15 PM
Question on Magnification Ratios jaieger Troubleshooting and Beginner Help 8 07-13-2010 09:45 AM
Magcro Magnification Ratio Question GregK8 Pentax SLR Lens Discussion 18 03-16-2010 10:17 PM
6x7 photo lupes for 3x LCD magnification jogiba Video and Pentax HDSLRs 0 10-19-2009 05:05 PM
All times are GMT -7. The time now is 10:46 PM. | See also: NikonForums.com, part of our network of photo forums!
